Question about GE DPSR483EA Electric Dryer
Squeling on dryer model #dpsr475ewoww - GE DPSR483EA Electric Dryer
  • 10,319 Answers
Replace the belt and tensioner pully to eliminate the squealing
Sears sell these parts in sets
Posted on Jun 07, 2010
Makeing a squeling sound
Could be belt slippage due to wear.
Feb 12, 2014 | Maytag ADE7005AYW Dryer
Dryer squels loudly
depends on the model it might need new rollers
Sep 05, 2011 | Dryers
The dryer heats good but my whispering appliance now squels
The roller bearing on the belt's tensioner is at fault. Replacing the roller is the first step and also replace the belt too
May 13, 2010 | KitchenAid KEYS750LQ Electric Dryer
Squeling when drying clothes
u need to replace the dryer drum belt.
Mar 05, 2010 | Dryers
Our dryer was makring a squeling noise no it just
NO TAKE OFF WHOLE PANEL FOR ACESS TO BELT .
Oct 20, 2009 | Dryers
Won't start all of a sudden. Power is getting to the unit, no breakers thrown. Interior light works... just won't run. What do I check first? GE model DPSR475EWOWW
First, find your breaker box and locate the breaker that runs the dryer. Now flip the breaker off and then back on. Now try the dryer. If it made not change. Gain access to the back of dryer. There is a small panel toward the bottom that you can take off. After unplugging the dryer, take the little panel off. Look inside and check the belt. Make sure it is tight and still going around the motor shaft and pulley. With this model, there is a switch that turns the dryer off so that it will not run when the belt comes off. If the belt is on, you will have a bad thermal fuse and bad cycling thermostat. The thermal fuse is located on the top of the element housing and the cycling thermostat is located on the blower housing. When the cycling thermostat goes out the dryer then cycles on the thermal fuse until it goes bad. This then cuts the power on one leg of the 220V coming to the dryer. Remember, a dryer runs off of 220vs. This consist of two 110v legs. The element is the only component inside the dryer that works off of both 110v legs. Some component work off of one leg and the other component work off the other. When you loose one leg, some things will work and others will not. I hope this makes since. It's the best way I can explain it. If I can explain any of this or help anymore, please send a comment back to me.
Please rate solution and good luck.
Sep 07, 2009 | GE Profile DPSR475EW Dryer
Squeling noise when operating
Needs a new drive belt, but you might get away with just cleaning the belt with alcohol and cleaning the pulleys also.
May 25, 2009 | Maytag MDE9206 Dryer
Admiral clothes dryer making a squeling noise
The only thing that I know of that would cause a squeling noise from star to finish is the belt. Replace the belt and you will solve the problem.
Dec 15, 2008 | Dryers
Belt Not Tight
The belt gets tight when you press the pulley arm down place the belt over the outer edge of the pulley and then over the motor axis. The belt then runs like in a "eight". Christian
Jun 26, 2007 | GE DPSR483EA Electric Dryer
GE DPSR483EA Electric Dryer Logo
223 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
