Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Shuts off and flashes orange twice ever 5 seconds. How do I secure lamp cover or replace the lamp on a Panasonic PT-50LC14 TV?
The same thing happened with mine. I had to have a technician come out & replace something called a "ballister". It cost me about $300.
Posted on Jun 15, 2010
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
Apr 25, 2015 | Panasonic Televison & Video
Panasonic TV shuts off after a couple minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | Panasonic PT-50LC13 50" Rear Projection...
No instructions on lamp replacement for this tv.can you help
With the TV off, unplugged and having cooled down for at least on hour (you can force it to cool faster see the manual), take off the front cover. Grip it from both sides and pull it away from the TV. Loosen the screw that holds the lamp cover and remove the cover. Next loosen the screw that holds the lamp in place. Pull the lamp out slowly by the handle. Handle the new lamp with a cloth to avoid oils and dirt getting on the lamp. Put in the new lamp making sure to properly align it in the TV. Retighten the lamp screw and then put on the cover and tighten its screw. Replace the front cover. If the screws and lamp cover are not correctly positioned, the TV will not work (a protective circuit is involved).
Next reset the lamp time (instructions should have come with the replacement lamp). Wait until the lamp notice disappears from the TV screen. Press and hold the Vol down button on the TV while pressing the Split/Play button on the remote. Hold both buttons until you see a notice that the lamp time was reset (about 4-5 seconds).
For a download version of your manual, see http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC14 .
I hope this helps.
Sep 05, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Tv will not power up Panasonic PT-50LC14
ok guy's i have the same tv and simular problems, first check the lamp light located next to the sd disk input (on the front). if it's not blinking then 2 things 1) more than likely it's the lamp if you haven't replaced it by now your one of the lucky ones, you can find them online for around $100, in which i paid over $300 for two differnt bulbs. the warrent only covers 1 bulb. 2) this happens to me once in a while try unplugging it let it set for a minute or two, replug it back in and try it again. but it depends if the light shines yellow (orange) and blinks twice, then try it again. you kinda have it cycle through and that should work. if not then unplug the unit, then take off the front cover and use a philips screwdriver remover the bulb (located behind the cover in the front) then i highly recomend doing this on a weekend pull out the shop vac and **** out the dust inside the lamp housing, then take off the back housing along with the left side speaker and first clean it out with a rag, then go through it with the shop vac. basically if dust builds up the unit will trap the heat and that it's why it will overheat and shut down.
Mar 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic DLP
If it has "Popped" then I would expect a rather catastrophic failure, and Lamps don't go "Pop.. they just fail more likely a Capacitor, Resistor, maybe even a semiconductor... so it's off to a reputable repairman get a "quote" and proceed from there.
Jul 22, 2008 | Panasonic PT-50LC14 50" Rear Projection...
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
324 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
