Question about HP Photosmart C6180 All-In-One InkJet Printer
MY HP PRINTER SAYS I HAVE A PAPER JAM BUT I CANT FIND ANY PAPER JAMMED. WHEN I TRY TO PRINT ITMAKES A NOISE LIKE WOODPECKER PECKING ON A TREE. HOW CAN I GET IT TO WORK AGAIN
  • winifred bertolucci Jun 09, 2010
    The carriage would not move at all...I cleaned it
    and now the cartriges are moving but it still is telling me there is a paper jam ... and the printer doesn't even pick up the paper....still makea a noise when the carriage moves.
    I HAVE TRIED ALL YOUR SUGGESTIONS....NONE WORK
    The HP 5280 ALL IN ONE printer says I have a paper jam, but there is no paper jammed.
  • 2,841 Answers
You did not list the model. Remove the back panel and you will find the jam.
Posted on Jun 09, 2010
    HP PHOTOSMART C5280 ALL IN ONE
    PRINTER SCANNER COPIER
    I HAVE CLEANED THE CARTRIDGES...NOW THEY MOVE.....
    I HAVE REMOVED THE BACK...I CANNOT FIND ANY PAPER OR OBSTACLES ANYWHERE.
    THE PRINTER STILL SAYS I HAVE A PAPER JAM.... FOR AWHILE I COULD NOT TURN THE PRINTER OFF OR ON WITH THE OFF/ON BUTTON...NOW I CAN.
    THE PRINTER DOES NOT PICK UP THE PAPER OR PRINT IT.
  • NOT ME Jun 10, 2010
    This article at H.P. describes in detail exactly what to do to solve this problem on your H.P. 5280.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
  • HP Master
  • 6,487 Answers
There's a big chance here that something or a small piece of paper cause this jam and we really need first to clear that to make the printer working again and you may need to get a flashlight to provide more light and also follow the steps from this link to clear that message.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00720198&lc=en&dlc=&cc=us&product=1153494
    President:
  • 1,561 Answers
Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
Look for paper through the opened back panel. Remove any paper you find jammed.
Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
Close the front access panel. Make sure that it latches back into place.
Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Take care.
Posted on Jun 07, 2010
  • winifred bertolucci Jun 07, 2010
    THE CARTRIDGES MOVE..... SOMETIMES....... AND THE SCANNER MOVES SOMETIMES
    BUT THE PRINTER DOES NOT PRINT.
  • Sulaimon Jimoh Olayemi Jun 07, 2010
    Among the most common problems with any make of printer are paper jams. A
    printer will jam for any number of reasons: It’s dirty, the wrong paper
    type is being used, or the rollers on the printer that feed the paper
    through its pathway are worn down. While cleaning the printer
    periodically and using the correct paper type are easy fixes, roller
    replacement can be a difficult job depending on the model of HP printer.
    For some HP printers, the rollers are easily accessible, but you'll
    need to completely tear down other models to remove the rollers.
    Regardless of the cause, when removing a paper jam, always pull the
    paper in the direction of the paper path, because pulling it backwards
    can severely damage the printer.
    Certain HP printers are more
    susceptible to paper jams than others. In my experience, any printer
    that holds the paper vertically and then pulls it down through the
    printer invariably ends up having paper jam problems.
    If the printer is not printing but works, you can uninstall the printer driver and install back on your system, because the driver may be corrupt.
    Take care.
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Printer jammed and paper was removed but now it says paper jam and won't print from a command from the computer
hi go into control panel find printer settings u will have to clear any printing commands in c whats printing........good luck
Sep 04, 2015 | HP PSC 1315 All-In-One InkJet Printer
States paper jam when I go click to print?
That's happened to me before on my HP printer. Try opening the printer and checking for any paper that might be jammed. Look very carefully, if you find paper that's jammed, carefully remove it. Close the printer. If you have the option to hit OK to clear the jam on the printer, do so, and then try re-printing.
Mar 01, 2011 | HP Office Equipment & Supplies
Having message jam inside rear door and can not find any paper jam
Not all of the paper jam was actually cause by paper. There are also instances that the media is the one that is jammed, causing to display a "paper jam" message.
If you can't find any jammed paper from the unit, you can try inspect the following cause..
1. Trays are loaded improperly or overfilled.
2. Tray 2 or tray 3 is removed during print job.
3. The top cover is opened during print job.
4. The media that is being used does not meet HP specifications.
5. The media that is being used is outside of the supported size range.
Also, try to tun HP toolbox.. on the Paper Jam options, click the Typical Jam Locations... to see the internal paper path and potential jammed locations.
I hope this solve your problem...thanks..
May 28, 2010 | HP LaserJet 2420 Printer
Paper jam with my photosmart c4280 printer- help!!
Try this link...It may help.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00860153&product=3192753
As for the cartridge jam try resetting the printer. Open it up, make sure there is not jam. Move the carriage over if necessary, hit OK. Then turn the printer off. Go to your computer and remove any documents from the print queue. Then, with the computer still plugged into the printer, turn the printer on.
Mar 11, 2010 | HP Computers & Internet
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
Paper stops half way, I get a message saying it's a paper jam or misfeed, but I can't find anything jammed
try to shutdown your printer and then ....arrange the paper properly on the tray or add some ..and then print an alignment page on it.....
May 17, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Paper Jam message when NOT jammed
Close all the running programs/applications on your computer.
1. Click Start --All programs - HP - HP Director/Solution center.
2. In Hp Director/Solution center Click Start - Settings - Print Settings - Printer Settings
3. Click on the Features tab. Set the Paper Type to Plain paper and Paper Size appropriately.
4. Click Ok. Close HP Director/Solution center.
Open the application and try printing.
Thank you.
Dec 23, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
444 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
