Question about Maytag Neptune MAH7500A Front Load Washer
Wont' spin or drain - Maytag Neptune MAH7500A Front Load Washer
  • Maytag Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineWont' spin or drain - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 07, 2010
WASHING MACHINE WONT DRAIN OR SPIN
did you get a solution as i now have this problem
Jun 08, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Wont spin or drain it only only hums when turn on
Either your drain pump is bad or something is stuck in it.  It won't spin until it drains so fix the drain pump, and it will spin.  You should be able to get at the drain pump by taking off the bottom panel, or back panel.
Dec 19, 2009 | Kenmore HE2 Plus Front Load Washer
Water wont drain and it wont go into the spin
if it is'nt making anny sound at all in spin its probly the lid switch
Dec 08, 2009 | Magic Chef Washing Machines
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Washing machine wont drain or spin all other cycles work fine
you may have a timer problem just advanced your timer on click ahead when it happenes if it drains or spin replce your timer thanks from giles
Mar 14, 2009 | Washing Machines
Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Dec 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Maytag Neptune MAH7500A Front Load Washer Logo
144 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
