Question about Sylvania LC320SS8 32 in. LCD Television
Black marks on screen
A few months after my TV was set-up, I cleaned the screen when it appeared to be dusty. However, there seem to be 2 permanent black marks that will not clear.
One or 2 people I know tell me that you should not use Windex on flat screens. I did so initially, not knowing you shouldn't use it and am unable to find at supermarket or dry goods stores any cloth or material that should be used for this purpose.
Is there any way to remove these marks, or must I just put up with them until the TV wears out?
  • 579 Answers
SOURCE: Black Rectangle on lower half of TV screen.
Turn off the closed captioning feature. If a channel or program doesn't provide the captioning, all you get is the black box. Just find the menu page for that and change the setup.
Posted on Jan 10, 2008
SOURCE: Black screen after 1-2 minutes.
Hi, I just fixed one I bought on eBay with the same problem. My problem was caused by the screen backlight inverter. Fortunately I had one from another TV I bought last year on eBay. The repair only took about 15 minutes. Your best bet is to contact Funai Corp. and really complain even if it is out of warranty. They make Emerson, Funai, Symphonic and Sylvania and all the parts inside are the same (from the same years). If that don't work look on eBay for one with a broken screen or some other damage, call your local dealer and see if they have the inverter from a broken TV or ask around. We have a freecycle group in Michigan that recycles things rather than throw them in landfills you may have one in your state too !
Good Luck,
Posted on Jan 25, 2008
JULIANFIX
  • 975 Answers
SOURCE: Black Screen
try this option , open the unit , look on the PC board , try to locate an inverter transformer ( its square with ferrite coil ) look on the back for a DRY SOLDER around that area , if not then try the POWER SUPPLY also , hope this helps
Posted on Apr 26, 2008
  • 6 Answers
SOURCE: the display only goes between normal and zoom
This is an EDTV capable of 1080i over component cables. It will also display 480p & 720p. Most likely its the video source determing the resolution you are seeing.
Posted on Nov 28, 2008
  • 476 Answers
SOURCE: there appears a black box on screens on certain channels
Hi, hit the cc button on your remote control untill the close caption display says off, this should eliminate the box from your screen
Posted on May 19, 2010
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
Sharp aquos LC-60LE640U flashing error code 2-5.
Dont buy a Sharp. Buy a Sony, Panasonic, JVC, Visio, ANYTHING but sharp!
Jan 27, 2013 | Sharp LC-60LE640U 60 Inch 1080p 120Hz LED...
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Screen marks on my samsung lcd tv.
Sorry not a solution just confirmation of similar fault on a Samsung 32" . I to have this problem which appears to be getting worse . started with 1 mark and has now spread to about 20% of the screen albiet numerous marks. It appeared after 18months to 2 years after purchase in 2006 so now 4 years old. I've accepted there's nothing to be done and out of warranty. Problem is purchase a new set Samsung or another. But will I have the same problem 2 years after??
Oct 30, 2009 | Televison & Video
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Nov 03, 2008 | RCA F32650 32" TV
45" mitsubishi TV with gray/black "water stains" on screen
If the plastic screen has not been damaged by chemical properties in the liquids, the screen does not separate. Time will tell.
Apr 04, 2017 | Televison & Video
LONG BLACK MARKS
Try firmly rubbing them out with a non-lint cloth.
Oct 29, 2007 | Philips 32PF5320A 32 in. LCD Television
Black Marks on T.V.
service call to determine if it a convergence fault or something alse.
Sep 09, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Sylvania LC320SS8 32 in. LCD Television Logo
106 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
