Question about KitchenAid KEYS700LQ Electric Dryer
Kitchen Aid Dryer KEYE67988LD wont start, checked power output to dryer, power in connection fine. No sounds, just dead.
  • beaulieu48 Jun 07, 2010
    We got as far as taking the back panel off, checked the white small fuse, it registered open. Thanks, I think we will try to replace this to see if it will work.
  • 166 Answers
You could have several problems but the first thing to do would be to check the door switch. Most of the time you can use a small screwdriver to push the switch in and out. you should hear a click when you do this if the switch is good. you can also use an ohm meter to check the switch if you know how to use one.
another culprit is the thermal fuse located on the back of the machine. you must remove the rear panel. it is usually a small white object with 2 wires attached to it. if for any reason the machine over heats this thermal fuse will shut the dryer down. it is not resetable and must be replaced if no continuity flows through it. if it is bad usually something caused it such as a stopped up vent , crimped hose or possibly a thermostat failure. check these items and clean out the lint on the outside of your house vent as well. don't use plastic vent hose and don't try to push the dryer up too close to the wall causing the vent to partially collapse.
Posted on Jun 07, 2010
  • 336 Answers
You can go to www.appliancepartspros.com type in your model number and you will find all the parts you need cheap. When replacing the thermal fuse they are going to suggest replacing the high limit thermostat also, the parts with shipping will be less than $25 so its a good idea to replace both.
Miele t1565c dryer has no power. It was working fine until my son ran his welder off the same circut as the dryer now it wont work
Have an electrician check all the connections, the load from the welder probably overloaded a connection.
Dec 01, 2013 | Dryers
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
Kitchen aid dryer Partial drying the cloth
First you should make sure the exhaust vent and ducting and lint trap is not clogged or restricted, birds/insect nests, or lint build up. If the dryer is heating up it is most likely an airflow issue.
Jun 05, 2010 | KitchenAid KGYS850LT Gas Dryer
My dryer just won't start when I press the start
The electrical breaker may not be turned on. Check the homes main electrical breaker panel and ensure the breaker marked Dryer is in the on position. If this does not work, you may need to call someone in to take a look at the dryer.
Jan 25, 2010 | KitchenAid Dryers
Kitchen Aid Electric Dryer Model # KEYE678BALO, won't start.
This is most often caused by a bad thermal fuse or thermostat high limit cutout. Check them for continuity (with the machine unplugged, of course) They should have continuity -- replace them if open. They should be available at www.appliancepartspros.com Also, if one or both are bad, check the dryer vent as they often are damaged by high heat due to a restricted vent pipe. The website above also has diagrams to help find the parts on the machine.
Dec 30, 2009 | Washing Machines
Trying to locate heating element on kitchen aid dryer
Do you have the part number, is so Put in (Find kitchen aid dryer Part# 111111* ) Or( Find kitchen aid dryer heating element* ). If this is a old dryer some parts are not made anymore. Any Dryer over 7 years old is no longer energy efficient. Hope This Helps.
Zipher
Oct 03, 2009 | KitchenAid Dryers
Kitchen-Aid Dryer has power to dryer , door switch is working ,and inside light is working but dryer will not start.
Check for a blown thermal fuse. It's about an inch long and is inside the rear of the dryer, usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Sep 11, 2009 | KitchenAid Dryers
The thermo fuse keeps going out on my kitchen aid dryer
you need to check the wall vent and dryer vent it sounds like 1 or both might be clogged,if blowing cold air know the heater box fuse has blown again-mike
Jan 24, 2009 | Dryers
Dryer wont start
I would check the door swith first.
Jul 15, 2008 | Estate TEDX640JQ Electric Dryer
KitchenAid KEYS700LQ Electric Dryer Logo
447 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
