Question about EliteGroup ECS 661FX-M P4 FSB800 DDR400 Motherboard (MOTEC11)
What video card should I need to put into fsb 800 661fx-m. Maximum
    Genius:
  • 1,189 Answers
Hi, click on this site, it will show you in detail some of the [Specifications] of "Maximizing your "Video," rate the help; if it do, thanks. http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=401&DetailName=Feature&MenuID=1&LanID=0
Posted on Jun 07, 2010
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
K7SV266AD Can I use 266Mhz athalon processor with this board, book says 100/133 FSB. If so what processors? Thanks
The Syntax K7SV266AD motherboard uses a VIA motherboard chipset.
It uses a VIA KT266A for the Northbridge, and a VIA VT8235 for the Southbridge.
About the motherboard chipset;
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
High-speed graphics is AGP or PCI-Express
A graphics card inserted into a PCI slot is Not high-speed graphics.
Neither is Integrated Graphics.
(Integrated Graphics is also referred to as OnBoard graphics.
ON the motherBOARD. The graphics chipset is soldered directly to the motherboard, and not to a graphics adapter card. {Graphics card}
The graphics chipset is a GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The Southbridge chip handles the slower capabilities of the computer.
It handles the IDE, and SATA capabilities of the computer.
It also handles the USB ports, Ethernet, and Audio, plus anything connected to a PCI slot, and Integrated Graphics, to list a few examples.
Motherboard Diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[For further information you may wish to search on Wikipedia,
A) Northbridge (computing)
B) Southbridge (computing)
C) Bus
D) PCI Local Bus
E) AGP (Accelerated Graphics Port)
F) PCI Express
G) Front Side Bus ]
Looking at the motherboard with the Processor to the top, and Ram Memory to the right, the VIA KT266A northbridge chip is below the Processor.
The aluminum finned Heatsink covers it.
The VIA VT8235 southbridge chip is down towards the lower right corner.
Looking at the specs for the VIA KT266A chip we can see,
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
1) It supports either DDR Sdram ram memory at 200MegaHertz, or 266MHz.
PC-1600 or PC-2100, respectively.
(DDR Sdram is clocked twice. Therefore the 133MHz Front Side Bus {FSB} support will handle 266MHz ram memory)
2) The Maximum ram memory it will support is 4GB. If you have the motherboard manual, you will know what the maximum amount of Ram Memory is, that the motherboard will support.
3) Will support Processors with either a 100MHz, or 133MHz FSB. (Front Side Bus)
AMD processors are 'Double-pumped'.
The VIA VT266A chip will handle AMD processors with up to a 266MHz FSB.
It will handle AMD Athlon, or AthlonXP, or Duron processors, with a maximum FSB of 266MHz.
http://www.via.com.tw/en/products/chipsets/legacy/kt266a/
The best processor will be an AMD AthlonXP with a 266MHz FSB, that fits in a Socket A (Socket 462) processor socket.
Watch the Voltage used. Look up the AMD processor you have installed now, and see what voltage range it uses. The new processor must use voltage in this range also.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
For additional questions please post in a Comment. (Upper right of your page)
Regards,
joecoolvette
Jul 04, 2011 | Syntax Computers & Internet
My p4vmm2 rev.8.1 has only 256mb memory card and 128mb video card, my question is what would be the maximum bytes for memory card and video card can i install. Offcourse the compatible hardware..tnx
Looks like the max is 2 x 184-pin DDR DIMM socket support up to 1 GB, which means you can get 2 512MB DDR266/200 2.5V DDR SDRAM chips.
as far as video cards, it will accept any AGP 4x or lower card. You could also put a PCI video card in it, but AGP is better.
Dec 28, 2010 | EliteGroup P4VMM2 V8.1 Motherboard
What`s the maximum processor upgrade for IBM ThinkCentre M51?
MAXIMUM CPU FOR IBM M51 = Pentium 4 650
3,40 GHZ / 2M CACHE / FSB 800 / HT / SOCKET 775 ( SL7Z7 or SL8Q5 ) they take 84 Watt, by the way, change the power supply,with connections for Pcie x16 graph-cards ,like 800 Watt. HD cards are not supportet, Max.- card is ATI x1950 Pcie x16 512MB. Do not try the ATI 5450 will not work.
Processors:
DO NOT THINK ABAUT THE P4, 651 / 660 / or 661 ,will not work .( multiplier is 17 ) and not supportet by the mainboard and chipset.
Nov 20, 2010 | IBM ThinkCentre M51 PC Desktop
Can I upgrade my 1Ghz processor to a faster 2 or 3Ghz? I have an EliteGroup 741GX-M, socket 462 desktop with an AMD sempron
yes, it is possible, but the Front side bus will limit the functionality so much that it wouldn't be worth it.
Jan 02, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
Maximum cpu speed for a matsonic ms8137c?
The Matsonic MS8137C uses the VIA KT266A chipset thus you'll be limited to a processor with a 100~133Mhz side bus frequency (FSB) alternatively referred to as a 266FSB chip.
The Athlon XP3000 uses a 166 dual FSB (alternatively refered to 333FSB) so even if you could get it to run it wouldn't be able to stretch it's legs being limited to the chipset's maximum FSB Vs. CPU multiplier.
Presuming your motherboard will support it (and I imagine it would), the maximum CPU you'll be able to run at full spec is a Thoroughbred 2600+ AXDA2600DKV3C (there is also a D prefix chip that uses 166Mhz FSB you don't want this one).
Early AMD Athlon processor specifications can be found HERE
Additionally you may need to also update your motherboard's BIOS version to take full advantage of any revisions (and subsequnet CPU support enhancements)
Jan 31, 2009 | Matsonic MS8137C Motherboard
Motherboard capable of running 533 fsb, running at 133
You would have to run the 533 FSB at times 5 or 6 to get 2.4GHZ.
And if you did you probably would not see any increase in speed
Just because a computer can do something does not mean it should
Nov 03, 2008 | Computers & Internet
My motherboard cant boot up my Video card
Is your motherboard 8X compliant some were only 2X or 4X please just checked your board properties it is only 4X compliant
Jul 28, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
GATEWAY 7330GZ PC NOTEBOOK
This link will provide you the required information.
Specifications
Part Number: 4997Gateway 7330GZ Notebook
System Gateway® 7330GZ Notebook Processor Mobile Intel® Pentium® 4 Processor 532 with HT Technology
(1MB L2 Cache | 3.06GHz | 533MHz FSB) Determine Your Processor Speed
Chipset Intel® 852GME Screen 15.4-inch Widescreen Ultrabright TFT WXGA
  • Maximum Resolution: 1280 × 800
  • Maximum Color Depth: 32-bit (16.7 million colors)
  • LCD maximum refresh rate: 60 Hz
Memory 512 MB DDR (1 × 512 MB), 333 MHz, DDR
Expandable to 1.5 GB Video Intel® Extreme 2 Graphics
Dynamic Video Memory Technology (DVMT) supports up to 64 MB shared video memory Audio PC2001 Compliant AC '97 Audio
Built-in Stereo Speakers Hard drive 80 GB HDD (4200 RPM) Optical drive DVD +/- RW Multi-Format
  • Write maximum: 8X DVD +/-R, 4x DVD +/- RW, 24x DVD+R DL, 24X CD-R and 10X CD-RW disks
  • Reads maximum: 8X DVD-ROM Disks, 8X DL/+RW, 24X CD-ROM disks
Media reader 6-in-1 Digital Media Manager
Compact Flash, Micro Drive, MultimediaCard (MMC), Secure Digital (SD), Memory Stick, and Memory Stick Pro Modem 56K ITU V.92 ready Fax/Modem Network 802.11g integrated wireless (up to 54Mbps)
10/100Mbps integrated Ethernet LAN Pointing device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces
  • 4 - USB 2.0 Ports
  • 1 - VGA External Connector
  • 1 - IEEE 1394 port
  • 1 - RJ11
  • 1 - RJ45
  • Microphone In
  • Headphone/Audio Out
Battery 8-cell Lithium-ion Dimensions 1.6-inches H × 14.0-inches W × 10.4-inches D Weight 7.5 pounds (8.65 pounds total travel weight)
Mar 24, 2008 | Gateway 7330GZ Notebook
Computers & Internet Logo
50 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
