Question about Samsung AW1203B Air Conditioner
Compressor will cut on run a few minutes and shut off hot air
Compressor will come on run only a few minutes and shut off blowing only hot air when set anywhere between 74 and 68 ?
    Scholar:
  • 45 Answers
The compressor is probably going out on overload. There may be a small refrigerant leak thus making the compressor run hotter than usual. If there is not enough refrigerant in the system, the compressor will not get the refrigerant back to it to keep it cool. This is a safety feature built into the compressor to keep it from overheating and locking up. You may want to take it to your local appliance store and have it looked at. Most of the time it usually is cheaper to buy a new unit than to pay for just the labor to have them fixed.
Posted on Jun 07, 2010
Ac works fine when fan is on low but fan cuts off after a couple of minutes on high
Bad fan motor. Multi-speed motors have a set of windings for each speed. Your high speed is bad so the only solution is to replace the complete motor. When motors are going bad they will over heat and kick out on the heat safety. As it cools back down it will start again for a short time again until it gets hot again.
Jul 12, 2015 | Coleman Dometic Duotherm Rv Air...
Just replaced the capacitor, and reconnected. Turned power on and heard a buzzing sound from the condensor, then the fan turned on. the unit only runs for a few minutes then shuts off
The buzz is the compressor failing to start.The blue or purple wire from the compressor goes to herm on the capacitor. If it's wired right and does not stare the compressor is bad.
Jun 23, 2014 | Bryant 2 Ton 17 Seer Air Conditioning...
My heater and air conditioner shut on and off
The air conditioner is controlled by in cab air temperature so if the air temp is low then the ac compressor clutch will cycle as the thermostat switches it on or off. If you want it to work all the time you may have to run the heat as well so that the thermostat is fooled into thinking that the air temp is hot.. Have the system checked out by an auto electrician
Dec 06, 2013 | Mitsubishi Montero Sport Cars & Trucks
Ac
You would need to find out if the compressor continues to run when the cold air stops.
Jul 17, 2013 | 2000 GMC Sierra
Air cinditioning wont stay on, it switches to heat and wont shut off
What do you mean when you say it wont shut off? is it blowing hot air or do you just feel a lite flow of hot air even if you have the settings to cold?
If this is the problem that you always feel hot air at low flow and the ac goes to hot air then i would say one of two things, first if you have the selector to cold and you feel hot air then there may be a problem with the blend door, this door move to allow hot or cold air, the door may be broken or just a bad motor that controls it. keep in mind if the ac system shuts down for any reason the air then will be warm, it will be about the same temp as outside and maybe a little hotter.
this problem almost sounds like the ac compressor shuts off and then you are getting the outside air which is hot, there are many reasons for the compressor to shut off, it could be the compressor clutch heating up and disengaging , this would be due to a bad compressor clutch.
another reason is the fans are not working, the best thing to do is when the system starts to blow warm check and see if the compressor is running, start engine and look at the front of compressor, with ac off the front of it will not move, and then with ac on the front will spin, check it out and let me know, if it blows warm air and ac is not working then it may be compressor problem but if you are getting warm air and the compressor is spinning then it may be a door problem.
This is hard to check with out testing the system, so i listed a few things to check and let me know the out come. also the ac blows cold for how long before it gets hot air blowing out of the vents, good day.
May 25, 2012 | 2000 Dodge Grand Caravan
AC will blow cold air for a few minutes then start blowing hot air, cut the engine and start it again and blow cold air for a few minutes then start blowing hot air again. Just filled up the freon and the...
you have moisture in the system this causes your expancion valve to freeze up an stop working, thats why it works for sort time and when it de-freezes stars working again. you need to do a EVAC & RECHARGE with a good AC service equipment, specially attention to pull vacumm por at least 20minutes so you get all moisture out of the system.
Good luck
Jun 05, 2011 | 2002 Hyundai Santa Fe
My compressor hose is running extremely hot...any reason why and do i have anything to worry about
Assuming that it's used in an open-air spot so that the intake air is cool, hot compressed air means the head is running hot.
Most small-to-mid sized compressors run warm after a few minutes, and some run fairly hot after 10 minutes.
If the hose is too hot to hold after 20 minutes, the first suspect is friction within the compressor's head.
This could be caused by poor circulation due to a low-quality oil.
It could also mean a blockage in the air-delivery system (ie: oil-dust gunk at a fitting causing restriction, making the motor work harder than normal.
Flush the oil reservoir, pull the feed lines one-at-a-time and flush out. Pull the intake filter and blow out the head & valves.
Refill the reservoir with Craftsman compressor oil.
Sep 08, 2010 | Porter Cable C2002 150 Psi 6 Gal...
PROBLEM WITH MY AIR CONDITIONER
Is the outside unit running? if so can you feel warmer than outside air blowing from outside fan? If not your system may have a leak and pressures low. You can also check the piping to and from the unit larger one should be cold small one should be warm
Jul 03, 2009 | Whirlwind FH-778 Air Conditioner
PORTABLE AIR CONDITIONER WILL COOL FOR A FEW MINUTES WHEN FIRST STARTED AND THEN THE COMPRESSOR CUTS OFF.BLOWS ONLY HOT AIR AFTER THIS.THIS HAPPENS ONLY IN HEAT ABOVE 90 DEGREES F.
see if the compressor have any ventalation,if so there is a clickson and overload on your compressor,the clickson over heats and cut out.
This can also be early sighns of the compressor packing up...
Hope the little bad news helps.
Good luck.
Sep 10, 2008 | Heating & Cooling
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Samsung AW1203B Air Conditioner Logo
260 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
