Question about WEIDERFITNESS.COM Weider Platinum Plus
What is the volts and miliamps of the Weider Transformer 212003
Weider platinum plus #WESY79740 &WESY99750 Voltage is 24vdc, 1.5 Amps , posity is center pin. (E.R)
Posted on Mar 12, 2011
Hello, Where is Crank position sensor ( Engine speed sensor ) on Audi A3 1,8 2003. and how i can test it ? Thanx
testing is easy ,connect to a multimeter on lowest volt /miliamp setting and then pass a spanner head over it rapidly and if it works it will show a voltage ,very slight mind but a voltage
Aug 01, 2011 | Audi A3 Cars & Trucks
Brand new battery however, have to jumpstart truck every morning. When I put a volt meter between the battery and the disconnected neg batt cable I get battery voltage. I had same issue last year but it...
it sounds like you have a parasitic draw when the truck is shut down. Your test does not test any thing. You need to put an ammeter between a battery post and its cable. You need to measure in miliamps (one thousandth of an amp). Draw should be about 50 miliamps.
A simple test is to just disconnect the battery at night for a few days and see if that solves the problem. If yes, you are chasinig something that is drawing current (amps) while the trcuk is off. Yoiu also should check to see if the battery voltage is around 14 volts with the engine running, that would tell you the alternator is working and charging the battery.
Make, model & Year?
Mar 05, 2011 | Ford Expedition Cars & Trucks
I need a 14.5 volt transformer 470 milliamp from a Keurig coffee maker. The part number on the transformer is T08839B and there is a model number on the transformer also U41AE20A1JJ2. Where could I find...
Had the same issue , Found a Philmore tr215 transformer...15 v 1amp. Had to modify the Keurig by cutting the plastic transformer compartment to fit the new transformer. also had to remove the transformer mounting bracket from the transformer to get it to fit. Keurig now works great.
Feb 02, 2011 | Keurig B50 Coffee Maker
Will not adjust weight
Plug the indicated end of the Transformer into the Rear Mech Cover . Plug the other end of the Transformer into a 120-volt outlet. All indicators and displays on the console will flash once; the console will then be ready for use. The motor may be heard while the resistance system calibrates itself. Important: Always plug in the transformer when using the resistance system.
Then, press and hold the NEXT button and the motorize resistance + button for five seconds. When the buttons are released, a number will appear in the REPS display. Press the NEXT button again, and then press the MOTORIZED RESISTANCE + button; this will start the recalibration process. This may take a few seconds as the motor moves between the lowest and highest resistance settings. When the motor finishes, unplug the transformer from the 120-volt outlet.
If you cannot hear the motor reset it self or cannot see display then with multi meter check DC voltage if not replace transformer , if you have DC voltage you will need to remove the cover locate the motor assembly disconnect the assembly from the upper electronics. Then apply a 12v DC voltage to the motor and see if it engages easily if not then replace motor. If motor functions properly replace connector back on the motor and use a multi meter connect it to motor and plug in the transformer and you should see DC voltage going to motor if not replace upper console.
Jun 01, 2010 | WEIDERFITNESS.COM Weider Platinum Plus
How to put together a weider pro 4100 gym?
Go to iconservice.com click on manuals input manufacturer and model name.
WEIDER & 4100
May 19, 2010 | Weider Nutrition Weider WEBE8077 Home Gym...
I resently bought a Weilder XP 800 and had to order a new transformer, I pluged it in and get nothing, Do I have the right trransformer or not? transformer is 120v, 24 dc volts?
There is a wire that breaks that is located inside of the pivot arm that hooks to the limit switch. (If you take off the back look on the RIGHT side of the machine.) When that breaks, the weight will not adjust.
I extended and rerouted my wires to run on the outside of the arm instead of the inside where they get nicked or broken by the moving parts.
May 11, 2010 | WEIDERFITNESS.COM Weider Platinum Plus
I tring to change thermosat I can not remeber what color go where
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Heating & Cooling
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
Console will not calibrate using steps provided in the manual.
Apr 10, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
Battery
You can get an universal AC Adapter such as the one sold at Radio Shack. The specifications should be 9 to 12 volts and at least 800 miliamps with the center tip being positive - this is reversible on universal adapters. A decent adapter should cost between $10.00 - $15.00.
Make sure that you plug in the charger on the battery pack, not on the 12 volts input from the PD-3070 - This is use only to power up the player, it won't charge the battery.
Good Luck.
Nov 20, 2008 | Astar PD-3010 Portable DVD Player
WEIDERFITNESS.COM Weider Platinum Plus Logo
620 people viewed this question
Top WEIDERFITNESS.COM Exercise & Fitness Experts
Tom Chichester
Are you a WEIDERFITNESS.COM Exercise and Fitnes Expert? Answer questions, earn points and help others
