Question about Carrier 38CKC042 Air Conditioner
A/C does not cool like it used to, unit runs
A/C does not cool like it used to & unit runs constantly. Most of the time it blows slightly cool to luke warm air. Last year's electric bill per month was near $800. Our house never got as cool as thermostat was set at. Freon level is full. Changed thermostat before last summer, from the original (mechanical) to a 'ritetemp' 6025 digital/programmable thermostat. I have a 5-wire configuration: Gray wire connected to 'O'
White wire connected to W2
Yellow wire connected to W
Red wire connected to RC
Green wire connected to G
Also changed out the heat pump defrost thermostat, as well as the defrost circuit board. I am almost positive that I installed these correctly since I took a before picture on my camera before doing anything. The thermostat was a little confusing, since I went from a mechanical to a digital.
Please help. Thanks in advance.
Jim
    President:
  • 1,515 Answers
Hi, heat-pumps are more complicated then a regular a/c to wire the thermostat. If your heat pump has a heat strip package installed, it takes more stat wires to operate it. Plus you have the reversing valve to switch over from heat to cool, so you need a wire for that. In a normal heat pump set up, 8 conductors are used to wire the stat, even though you may not use them all. The O terminal is for the reversing valve. It should be orange for this unit as cooling, the reversing valve is energized in that mode. The only unit that is made today that is backward from this is the Rheem and Ruud units as they are energized in the heat position on the B terminal. Are you sure you have put on a heat-pump thermostat? You should have terminals like this, R, O, B, W-1, W-2, G, Y, W, C. On a gas fired heat and cool unit, it will be 5 wires, RC, RH,G,Y, and W. The Red wire will be connected to either on of the R terminals as they will have a jumper to connect the 2 wires. I have never seen a gray wire in a thermostat cable? I would go to the indoor and outdoor units to see where this gray wire is connected to on the board. Y is for cooling, yellow. R to RC is right. G, green is for fan, W is for 1st stage heat, O should be to the reversing valve at the outdoor unit to change it over from heat to cool and orange in color. You may have it wired so that your heat strips are energized the same time the cooling is and they both are on! I have seen this many times and this would explain the high bills and low cooling. Check your stat Jim to make sure you have the right one. You should also have a emergency heat switch on it, and auxillary heat. The problem is in the stat. When it is on, go to the indoor unit to feel the duct to see if it is warm from the heat strips being on. If so, you can disconnect them until you get the right stat to run this unit right. Keep me posted.
Sincerely,
Shastalaker7
Posted on Jun 07, 2010
  • 146 Answers
Sound like your system is under sized. for every 400 sq ft of living space you should have a ton of ac or 12000 btus. also check and see if your attic fan is working. any drafty windows or doors. your supply temp should be at least 20 deg colder then your return temp. also check your filter should be changed every three months this will help with air flow.
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
Just asking how many amps existing Sanyo SAP-K181AHA would be connected to in Australia. Need to replace it, is 4.5Kw cooling and same price to replace with 7Kw but unsure if 30amp already in place
The 4Kw constant speed Ac will draw about 7.6 amps @240vac while the 7Kw Ac unit will draw around 13.8 amps @ 240vac. This is normal running. extreme conditions will be slightly more no doubt. The figures are approximate.egardsCol R.digital controls.com.au
Mar 05, 2011 | Heating & Cooling
Dometic air conditioner blowing cool air
When the cooling slows down, but water is still running off, usually something is icing up. You can turn the unit off, and let it thaw, and try again. Sometimes, if the humidity is high, this is more pronounced. It sounds like you are low on refrigerant. That implies that you have a slight leak. You should have the unit serviced, and the leak repaired.
Best regards, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
Fan in our Sharp "Comfort Touch thru-wall a/c stopped
Unless the Unit can be cleaned ( you claim it cools?) but not enough. The age of the Unit is not in you Question, the amount of time you got for 100 bucks is pretty good being you purchased a USED UNIT. With the type of use you claim Running 24/7 and about 5 months of cooling - I'd say you never cleaned the Unit from day one - that might cost you about 100 bucks if the unit can be done in the yard by a serviceman. Chemicals can hurt the Unit if not done properly ( and yourself). It sounds to me like you use it for a Business - if so you can purchase one and write it off .
Jul 18, 2009 | Sharp AFR120NX Thru-Wall/Window Air...
Cooling fan running constantly.
the cooling fins are clogged, u need to get a small vacum and clean the area
May 09, 2009 | Computers & Internet
Fan on amp runs constantly. will this drain my battery?
Yes, and would imply that the amp is powered up all the time.
You should correctly wire your system by
1.Connecting the constant 12vdc input wire to a constant 12vdc source to power the in-dash head units memory.
2.Connecting the switched 12vdc input wire to a switched 12vdc source to power the head units primary functions.
3.Connecting the remote output wire (typically a blue wire) from the in-dash head unit to the correct terminal on the amp, so the amp will only power up when the head unit is on.
4 Remember to run the signal (speaker) wires in a chase separated from the amps power wires, so as to avoid a buzzing noise in the speakers.
5. Always use an in-line fuse on the amp and the head units main power wires.
Note: A properly powered amp will produce a better sound quality then if it were under powered, so be sure to use the proper wire gauge as your amps power supply.
Good luck
Aduz
Mar 22, 2009 | AudioBahn A2002T Car Audio Amplifier
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
I have a technics su x502 amp & it works for a while then goes off & then comes back on after about 5 mins,the rest of hifi stays on its just the amp.
take out the cooling unit (the fan) and use a cpu fan out of a pc connected to an external power source like a 12v dc/ac adaptor and use it to blow constant cool air through the hole onto the heat sink. i know it sounds like a ruff job but it does work, my amp doesnt even get hot and it plays all night long without cutting out once. you will get noise from the fan constantly on but i just turn it up louder. this is just a ruff quick fix.
Aug 09, 2008 | Audio Players & Recorders
Amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Dec 21, 2006 | Infinity BASSLINK Car Subwoofer
Carrier 38CKC042 Air Conditioner Logo
359 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
