Question about Kenwood KDC-MP342U Car CD Player
Installed unit, there is obvious power, but the display does not light. Will accept and eject cd, but will not play.
    President:
  • 720 Answers
If you can turn the unit ON/OFF and change stations using your faceplate, then the faceplate is OK.
The problem lies with the internal display resistors.
Check out my tutorial which will explain how to repair this fault:
http://www.fixya.com/support/r16293427-repair_no_display_kenwood_faceplate
Cheers,Scott
Posted on Feb 01, 2013
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
At times a radio can have voltage at the yellow (12v memory wire) and no voltage at the red (12v ignition wire) which turns the radio on and off. If this is the case you may have a blown fuse or if it is a data based system the factory radio turns on with data and not voltage. If you have a data system in your vehicle there will be no 12 ignition wire present. You will then have to use a data/can-bus interface (recommended) or run a wire to and ignition source (this method does not retain any factory data features or safety chimes)
Posted on Jun 07, 2010
Hi - we have a Roberts MP53 DAB radio. When finished playing the cd we press eject with either the remote or on the unit and although it says eject on the screen it doesn't. After about 10 secs the visual...
Mine did the same at first. I turned mine upside down and pressed eject and that worked to get the CD out then let it warm up to room temp and all is well.
Jan 16, 2010 | Electronics - Others
The cd will not eject from the unit
you need to call radio shack or a stereo place to see if they can help if you take the loader out and bring in.
Jan 01, 2010 | 2005 Mercury Mariner
Radio not playing
it sounds like you didn't hook up both your power wires on your cd player. there is a red and yellow power wire. one is constant power to keep memory and the other turns on the radio when the key is turned. check to see if both are hooked up
Jan 11, 2009 | Car Audio & Video
JVC KD-G200 cd player
I would suggest checking the accessory (red wire), the yellow is a constant feed from the battery, which will allow the clock to be displayed no matter what. The accessory wire is what is used to turn on the cd player. You may need to restrip the red wire and check the lead going to the red wire with a test light to make sure it is getting a voltage light.
Mar 03, 2008 | JVC KD-G200 CD Player
Pioneer CD/Minidisc Player FH-P9000MD Problem
The remote control missing shouldn't be a factor - Pioneers will usually select the same sources with the "source" button as they will with the remote.
I would suggest 2 things - first, try different CDs. If it's accepting and ejecting just fine it may be a problem with reading your CD (I'm assuming you haven't tried this already). Ideally use a regular audio CD (not an MP3/WMA disc) that is relatively scratch free.
If that doesn't work, check to see if the initial settings can be adjusted to enable CD play.
To get to the initial settings menu you need to hold the "source" button until the unit powers off (the car's key will still need to be on at this point). Push and hold the "function" button and it should go into a menu with various adjustments, such as clock, aux enable, etc...
There may be a setting in there to enable CD play. I realize that the display may also be in Japanese but I'm hoping it will be somewhat intuitive for you - you seem to have a decent technical grasp on things already.
Feb 22, 2008 | Car Audio & Video
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
CD WONT PLAY
It sounds like it is attempting to read the t.o.c. (table of contents) which tell the unit where everything is on the cd,and failing to do so, then ejecting, the first thing to do is try cleaning the lens and if there is no change then replace the laser pickup
Nov 21, 2007 | Car Audio & Video
Soundspace 8 - Disc eject / play problem
Hi Kev Frey, Have you checked the mechanism for a broken or loose belting or possibly a broken gear teething. With Regards, Edmund
Aug 13, 2007 | Nakamichi SoundSpace 8 CD Player
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
Brand New Unit Will Not Accept ANY Type of CD
I am having the same problem but only with a KDC-MP335 unit. I installed it in a 1995 Jeep Grand Cherokee to the stock system, pretty easy install just matching colors for wires and everything works (Radio). but not one CD plays. it says reading and it acts as if it is playing the tracks but no sound... what is going on? did I mess up wiring it or something?
Oct 03, 2006 | Kenwood KDC-X890 CD Player
Kenwood KDC-MP342U Car CD Player Logo
166 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
