Question about Electrolux Frigidaire Affinity AGQ8700FE Dryer
Frigidaire Affinity is not drying. Code #'s E68 and E4A
This problem began two or three weeks ago. At first the code E68 appeared. I pushed the cancel button. It went away.
If I leave the door open, the dryer lights stay off.
If I close it, the timer stays on at 40 minutes or the code # E68 comes on.
SOURCE: Frigidaire Affinity Front Load Electric Dryer
E68 indicates one of the panel buttons is stuck.
Posted on May 16, 2008
SOURCE: Our dryer is beeping and
I found via a Google search that E68 means one of the keys is jammed. Looking at it, it was pretty obvious which one, so I pushed it in and re-centered it in its casing. That did the trick.
Posted on Jul 06, 2008
SOURCE: frigidaire affinity dryer problem
help[ my affinity dryer is somehow tearing /slashing rips in my clothes.
Posted on Sep 05, 2008
dragonsthatk
  • 547 Answers
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Posted on Mar 13, 2009
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
Posted on Jun 22, 2009
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
Why is my Frigidaire affinity showing code E68?
Good Morning Gary,
I understand you are receiving an E68 code on your Frigidaire Affinity washer, model# ATF7000E. The E68 code states that there is a current leak to the ground on the heater or there is a fuse open. This could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code E4A on my frigidaire affinity dryer
This is a board communication problem, you need to replace the control board. If you send me the model # I can tell you what the part number and price would be.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Dec 02, 2008 | Frigidaire Dryers
Our dryer is beeping and is displaying an error code of E68. I hit Cancel to try to reset it, and it goes back to numbers (20 minutes or whatever), then after a couple seconds goes back to E68. I hit...
Jul 05, 2008 | Frigidaire Dryers
message "ad" showing on my affinity frigidaire, anything wrong with this?
Apr 01, 2008 | Dryers
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Electrolux Frigidaire Affinity AGQ8700FE Dryer Logo
133 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
