Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Spectra XL 44 oven takes too long to heat up
This problem just started. Yesterday it took over an hour to get up to temperature and today it got up to 157 and stayed there for 15 minutes until I got frustrated and shut it off. The broiler works perfectly.
I just put it on "clean" to see if maybe there was a clog that needed to be burned out. The bottom flames were clearly visible when I pressed "start", however I can't see any flames on the bottom now; just the top.
Does anyone have an idea as to what the problem is?
  • 7 Answers
SOURCE: GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Posted on Sep 28, 2007
fridgetech
  • 473 Answers
SOURCE: GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 05, 2007
How do you get to it? On my stove there is no access panel
Posted on Mar 06, 2008
TaPuna
  • 70 Answers
SOURCE: pilot will not light, oven
hi there, I think for your oven not working you could have the clock set to automatic, Make sure it is on manual and you be good to go. :)
Posted on Sep 07, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Spectra XL 44 wont keep temperature
Replace the oven temperature sensor part # wb20k0004
Posted on Mar 18, 2009
GE XL 44 oven will not come up to temperature. Oven lights but will not heat beyond 250 degrees.
The most probable reason the oven isnt heating very well is because of a weak igniter,since that igniter is weak its having a hard time fully opening the gas valve so the flame is very small and thusly not producing much heat,by replacing the igniter the gas will flow properly and heat to a high tempature.
GENE
Oct 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE Spectra XL 44 takes 45min to preheat to desired temperature ie: 400 degrees
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 16, 2010 | GE Kitchen Ranges
My gas oven will not heat up above 300 degrees and
You may have 2 problems.
One. The temperature sensor could be bad. You can remove the temperature sensor and check it with a ohm meter. It should read 1050 to 1150 ohms. If not. It is bad.
Two. The glowbar ignitor could be bad and not igniting the gas safety valve.Open the bottom drawer of the oven and set the oven to bake. The burner should light in 60 seconds or less. Re-light should be about 30 seconds or less.
If it takes longer the ignitor is bad.
Dec 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
F3 code on ge xl 44 gas range
F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact
Jun 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Mar 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL 44 gas kitchen range. Oven does not work
Sounds like the switch module is defective.  You might get lucky if you power down the stove for half an hour and then reapply power.   Sometimes they reset.  If you, enjoy.  If not, you will need that module.
Nov 09, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
