Question about Cakewalk Sonar 2.0 XL
How can i record on sonar le
Im trying to plug my mpc directly to my
    Sergeant:
  • 269 Answers
Found you directions here
http://www.cakewalk.com/oem/sonar_le.asp
Melody
Posted on Jun 07, 2010
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
I bought this microphone w/ sonar LE. The mic is
You can probably solve your problem by plugging your mic into a powered usb hub, then plug the hub into your computer.
Jul 01, 2010 | Samson C01U Consumer Microphone
Timing after recording. and midi composing
May I suggest you try to adjust your audio settings inside Sonar. Also it is a good idea to always keep your C drive well defragmented. I once had this problem using Sonar LE and the only way I got rid of it was after formatting my C drive and reinstalling the drivers and Sonar again. After that the problem came back and then I upgraded from the SB Live to Audigy SE.
Make sure you also have lots of free space on your C drive and have a decnt amount of ram.
May 11, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Sonar 4 and midi sound cuts offat start of playback
If you are recording from bar 1 at time 1.00 you might want to start recording one or two bars later. So try starting your song on bar three istead of bar 1
Mar 22, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Triton Le
when you are setting your midi track on the mpc are you changing to 2A-Device02 for the 2nd track? 3A-Device02 would be the 3rd track and so on. Let me know if that helps. you should make a new track for each instrument you record from the triton to the mpc, helps when dumping.
Feb 18, 2009 | Korg Legacy Collection
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
PLAYBACK PROBLEM
need to know if you use headphones while recording, if not it could be feedback from your monitors or even the phones.reasons phones too loud or mic gain too sensitive.
May 28, 2007 | Rode NT1A Professional Microphone
Timing and noise
That's usually caused by problems with the usb port on your computer. The best solution would be to buy an PCI USB CARD that you would use only for your UAFX4.
Aug 09, 2006 | Edirol UA-4FX External Sound System
Cakewalk Sonar 2.0 XL Logo
73 people viewed this question
Top Cakewalk Computers & Internet Experts
Dan Shibata
Dan Shibata
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
