Question about Kenmore Dryers
Change belt on Kenmore Electric Dryer Model
How do I change belt on Kenmore Electric Dryer Model 110.66822690
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
jsrock516
  • 5911 Answers
SOURCE: Don't know if this is right model
Okay...took me a while to get a good cross reference on this one. Drop the last four characters of your model number and place a "110." in front of the remaining numbers. That way the number reads 110.86921100. The "110" identifies the manufacturer. Your dryer is made by Whirlpool. If you go to searspartsdirect.com and type in the model number I provided, there are a series of drawings on the next page showing an exploded view of the layout of your dyer. Does this look familiar to you? Under the "Cabinet" heading you will find the dryer belt listed as item number 56 (part number 341241). For a diagram of how the belt goes on, go to repairclinic.com and you will find a dryer belt diagram link listed under the "Repair Help" section. Locate the Whirlpool diagrams and you will use drawing "K". I apologize if this sounds like absolute madness. If you get confused, please post back and let me know. I hope this answers your questions.
Posted on Jul 23, 2008
TheMobilian
  • 8220 Answers
SOURCE: Replacing the belt on my kenmore electric dryer model # 110.8756.
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out and clean out the dryer. Oil the wheels and idler. Replace the belt using this diagram . NOTE yours is lower right:
Posted on Dec 22, 2008
Fame_Guru
  • 483 Answers
SOURCE: How to get into the cabinet?
Kenmore dryer belt
  • UNPLUG DRYER
  • remove lint filter
  • remove two screws in lint filter panel securing cabinet lid to filter frame
  • with putty knife or other blunt blade, depress clips ~2inches in from the front corners of the lid to release cabinet lid
  • tilt lid up
  • remove 1 screw from each side 1/3 the way down
  • remove cabinet front and door
  • motor bearings tensioner are all visible
  • lift out drum forwards
  • check support rollers felts and nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage, and you dont want to do it again next month)
  • make sure tensioner is still installed in cabinet base, sometimes breaking belts pull them out
  • loop belt around drum at prior wear marks
  • reinsert drum
  • pull tensioner to end of travel against spring
  • loop belt around motor pully and tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off.
Thanks
Fame !
Posted on May 04, 2009
  • 35 Answers
SOURCE: kenmore dryer model#110/62622100 will not atsrt
check to make sure you dont have a blown fuse or a triped breaker if they are fine if you have a volt meter take the back panel off on the control are or if it is the other kind losen up the two screws in the back of the control area and when you get it lifted up make sure unpluged then put the volt meter on the beep mode when probes touch then put it on the two spots on the swicth and push the button if it beeps it is good if it dont it is bad and that part dont cost too much another thing you should check before you do all that check make sure you have 220 volts on that plug if the switch is good and you have 220 volts it probably the motor or the timer they both or expensive
Posted on Jun 07, 2009
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Part number 8066065 kenmore heavy duty super capacity dryer electric belt for dryer tub
Hi mousessugar2...
Go to the following webpage and order your belt...it has changed numbers
It is no longer part number 8066065...It is now a Part number 341241.
Please take time to rate me thumbs up.
http://www.appliancecarestore.net/replacement-for-kenmore-amp-whirlpool-dryer-belt-341241.html
Sep 24, 2011 | Kenmore 63942 Dryer
My kenmore electric dryer turns on and heats but the drum doesn't turn?
that would be a broken belt, or the motor, I say belt. You will need to open the top of the dryer and look in the middle of the drum for a belt, which is not there I am sure, here are some websites,Tim:
how to change belt:
http://www.ehow.com/how_4814455_change-kenmore-dryer-belt.html
belt routing Kenmore is same as Whirlpool:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.htm
May 23, 2011 | Kenmore Dryers
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
No tension on the tension pulley.
Check that the slide/rod /bracket is not jammed on the adjusting mechanism.
Jan 18, 2010 | Kenmore Elite HE4 Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Need a belt for a kenmore 78708 electric dryer
The belt will be a FSP (factory specified part) # 341241
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Amana dryer dle330raw tenson on belt
Usually very simple. You need to get the diagram for our model. Most dryer belts go around the drum, around the tensioner pulley and around the motor pulley. You need to take off the front, top and rear panel depending on model. I can change mine in about 15 minutes complete job.
Jan 08, 2009 | Kenmore 82822 Electric Dryer
Kitchenaid dryer
Yank the filter out the top.
remove the 2 phillips screws in that filter housing on the top of the machine so you can pop the spring clips and get the top up. Remove the front and get the drum out. Oil the wheels and idler and rerout the belt using this PIC.
Jul 30, 2008 | Kenmore 62802 Electric Dryer
Dryers Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
