Question about Samsung Computers & Internet
Need to remove stand to mount on wall - Samsung Computers & Internet
    President:
  • 1,335 Answers
What is the model number?
Posted on Jun 07, 2010
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
How do I take the stand off of the TV? (For wall mounting)
There will be clips or screws on the back of the TV which will need to be removed and the base stand will slide out of the bottom of the TV. Do NOT start taking screws out of the back of the TV without the wall mount with instructions. Sometimes there are spacers that need to be used with the wall mount and generally only four screws need to be removed from the TV. The TV should have instructions on how to prepare the TV for a wall mount as well. All are different, but very similar to do. If you lay the TV face down on a soft surface (do not slide it around) you probably can see what screws need to be removed to remove the TV base. Keep the screws with the stand for later use if desired because you will need them to re-install the case later. Here are two examples;
I hope this helps and good luck!
Nov 12, 2009 | Televison & Video
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
I am trying to remove the stand on a LG Model : 52LB5D. I have removed the 4 screws on the back but can't remove stand. It feels like there is another screw or something holding it in.
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
Dec 09, 2008 | Televison & Video
Cannot figure out how to remove stand so I can mount TV on wall
did you figure this out? I only ask because I need the stand for my TV. Could you sell me yours?
Thanks
Anthony
amsaxo@yahoo.com
Dec 02, 2008 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Computers & Internet Logo
154 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
