Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Does not drain, water stays in the bottom of the unit.
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherdoes not drain - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jun 07, 2010
Constantly runs the drain pump when started
You don't list the make or model or age but has it always done this? Some models will automatically run the drain pump first as part of their programming before starting the actual cycle. Then, the unit will sense the load, start adding water steadily until the correct amount is reached(based on sensed load size), then wash. However, if the drain pump is being initiated at the wrong time, or stays on and no water is able to stay in the tub, there could be a problem with the water level sensor--it thinks water is already in the tub. This usually happens from a blocked water sensor tube(a plastic tube that is connected from the bottom of the washer tub to the water level sensor). Or, the problem might be with the main washer control board.
Aug 21, 2015 | Washing Machines
Water stays in bottom drawer
Hello Joaquin Medeiros - Often when there is standing water in the bottom of the dishwasher, it is because more than likely the control or drain pump assembly is faulty and possibly need replacing. However, if the unit is making a grinding noise then it is recommended for the drain motor to be diagnosed. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 17, 2013 | Frigidaire 24 in. FDB750RCC Stainless...
Water is draining into my bedroom when a/c is on ihave a freidrich model#ss12j10ar-1? can it be fixed or should i just buy a new a/c?
Before you buy another one, check two things:
1. make sure the unit is tilted back in the window and not forward. The unit has to be tilted back away from the window about a half bubble on a level in order to drain out the back.
2. if the unit is tilted in the window properly and still draining out the front, you will have to take the case off the unit and wash it out good with a hose and sprayer. If the unit is not rusted out on the bottom, the drain is stopped up that drains the water from the front coil into the base of the unit. The water should be draining from the front to the back, and excess drains outside on the ground. Hopefully, it just needs a good cleaning. Hope this can save you from buying a new unit. Stay cool. Mark
Jul 10, 2011 | Friedrich QuietMaster Electronic SS12J10AR...
Unable to locate the drainage for condensed water. I could look inside and see that water is accumulating at the bottom. Feddlers AEJ12E7AG, window unit. Thank you
Hello, most window units evaporate the condensate by having the fan blad sling the water on the condenser. Because the condenser is warm/hot it will evaporate. You shou.d be hearing a sloshing sound after the unit has benn running for a while, this indicates that the fan blade is picking up the water from the bottum of the ac.
May 31, 2011 | Fedders AEJ12E7AG Air Conditioner
The water stays in the bottom of the dishwasher .
The drain pump is not working fully to discharge off all the water in the drain cycle. You must check the drain outlet for any blocks in the drain valve/pump. open and clean the unit. If ther pump is not effficiently pumping out in the ddrain cycle then the unit must be changed or serviced.
Oct 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water leaking inward
There should be a drip tray that catches all the condensation and funnels it out the back. Check for holes, cracks or a plugged drain hole.
Aug 30, 2017 | Frigidaire FAC124 wall/Window Air...
My bosch dishwasher will not fill with water. I have manually filled it but it just pumps it out when I switch it on.
the unit is going into drain mode. check your hose for leaks. when water leks in the base of the unit the float switch is activated and the unit will stay in drain mode until the water is removed. check float by removing side panel and look into bottom base for water.
Feb 25, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water in bottom of refrigerator after the freezer was defrosted.The water stays in the unit, drips to the bottom and in the lower drawers, not into the drip pan in the bottom.
The internal drain may be clogged with debris, I'd check that if visible. If not that, may be defect from manufacturing process.
Feb 04, 2010 | Refrigerators
Bosch logixx dishwasher draining constantly even with door open
there is a leak . when the unit stays in drain mode that means there is water at the bottom of the base. The float switch stays in drain mode untill the water is removed. you must take off the side panel to remove the water,let me know what happens.:)
Nov 08, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Seems to be filled with water In window model, on about a 10 degree pitch out the window. Some water sputters out of the vent that blows out the cold air.
Your unit has a clogged drain passage that's why the water is staying in the front of the unit.If you take the unit case off look for a drain trough in the bottom of the a/c where the metal wall is that the fan mounts to thats where it is,clean it out and the water will flow to the back of the a/c and not blow or drip inside your house.
Aug 25, 2009 | Haier hwr10xc6 Air Conditioner
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
330 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
