Question about Estate EED4100SQ Electric Dryer
Dryer heatin up but not dryin clothes
I was told the hose needed to be cleaned out i cleaned the hose already what else can i try
  • lawrenceearl Jun 07, 2010
    i asked another expert why my dryer was heatin up but not dryin the clothes, he suggested that i clean the hose i did already so do you have any more solutions
  • 10,319 Answers
Check the thermister and the moister control sensor
Posted on Jun 07, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. When the dryer wont dry clothes it is usually caused due to three things: Mainly the Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jun 07, 2010
    Solution still remains the same...
Why does my front load ge washer leave lint on the clothes?
We found that my family was not cleaning the kleenex and stuff out of their pokets. Once we checked all pockets very little lint appeared.
Dec 03, 2014 | GE Washing Machines
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
My dryer not heatin up and dryin clothes hotpoint aquarius CTD00
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
We have a full video library on appliance repair video’s
Dec 30, 2009 | Hotpoint Dryers
The dryer is not dryer the cloths. I think the lint filter is clogged
Your lint fllter should be readily accessible and should be cleaned before each cycle. If this has been building up for a whle, I highly recommend cleaning the interior of the dryer. This requires removing the front panel and vacuuming the lint out of the machine.
Be careful not to touch any of the heating elements with the vac.
Also it is a good idea to clean the exhaust vent periodically. Detach the flex connection from the machine and check that it's not plugged as well. Hope this gets things dryin' again.
Let us know if you need further details.
Jul 01, 2009 | GE Dryers
Doesn't Dry Thoroughly
if you have not already you need to clean out your vent hose. if you have a bunch of lint build up in the hose or in the blower wheel of the dryer it won't move air through the dryer that needed to dry.
Jun 24, 2009 | Dryers
Takes a long time to dry clothes
You might want to clean out the exhaust hose where it goes thru the house. Also vacuum inside the unit to if you havent done so already. Let me know if this helped
Apr 27, 2009 | Dryers
Dryer not dryin well
Check the lint catcher. Efven though you may have taken out lint it could still be clogged. Take it out and run under water. If water starts to collect then you have an invisble layer that comes from fabric softner. You just need to clean it out with warm water and soap. The only other thing it could be is lint has collected on the vent leading outside from your hose. Just simply remove it and you should be ok. I've had simliar problems with both scenerios.
Sep 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer not drying clothes
Make sure that the flex hose going out from the dryer is not blocked. You should check it from both the back of the dryer and all the way to wear it vents outside. It could also be the thermostat, which is cheaper to replace than buying a new dryer.
Sep 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate EED4100SQ Electric Dryer Logo
20 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
