Question about Pool & Spa
My coleman hot tub control panel displays 5nl what does this mean?
    Habit-Forming:
  • 77 Answers
It's supposed to be Sn1, but it looks like a 5. ;-)
Sn1 usually indicates a problem with the High Limit temperature sensor, but it can be caused by other faults such as restricted water flow and I'm assuming that your Coleman has the Balboa controls.
Check the operation of the Circulation pump / Pump 1 and if the water flow is adequate you could try changing the sensor. If however you're unsure about anything, seek professional help.
If you're in the UK I can help with parts and if you're local I can possibly come and check the hot tub for you.
http://hottub.synthasite.com
Kind Regards,
Ian.
Posted on Jun 18, 2010
My dream maker big eze hot tub the jet light on the upper control panel just keeps blinking what does that mean
Are the jets coming on when you press the button?
Try unplug the control from the board and plug it back in.
Dec 01, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub won't start
More info needed.
I have had many hot tubs and had to fix them all.
First check:Plugged in, right?Is the GFI tripped?
Is there power on the HT control panel? little red or green lights, lcd display info, anything? Look up any codes you find.
After that little inspection, a number of things can go wrong. First Unplug the unit, then Open her up and look for any sort of anomaly. Photograph and post what you find.
GL,
John
Nov 03, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
Cannot get temperature buttons on hot tub to change
Do the other buttons work? Is the control panel locked, some spas have a control panel lock to prevent kids from playing with the temperature. Are any of the buttons stuck in the de-pressed/down position? If neither the problem is likely in your topside control which means it will need to be replaced.
Sep 18, 2012 | Pool & Spa
I have a coleman emerald 455 hot tub and I have managed to lock the electronic control panel. How do I unlock?
press program and then mode, it will display "0" and will be unlocked. u locked it by pressing program twice
Nov 05, 2010 | Pool & Spa
Coleman Hot Tub Model 411
This spa was manufactured by Maax. Try Maaxspas.com for your owners manual.
Nov 23, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
What does OH mean on a hot tub control panel
OH stands for overheat. This normally occurs when the water temperature of the spa reaches over the safe temp of 104 degrees, as a result of a failure in the thermostat control. But if you receive this error and the water is not scorching, (a fairly common occruance) then the temp sensors have likely failed. Replacing the temp sensors will most likely rectify the problem. If the problem persists, then the circuit board is bad.
Oct 31, 2009 | Coleman (5040B750) Patio Heater
I need an owners manual for a Coleman Spa Horizon series 447
Chuck, did you find the manual? If not I have one with my spa maybe I could copy it for you.
Ron
Sep 04, 2009 | Coleman Sport & Outdoor - Others
Can't unlock the control panel
Usually in sequence... Program-Mode-Temp Down... Or temp Up to lock
May 24, 2009 | Coleman (5040B750) Patio Heater
Pool & Spa Logo
705 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
