A/C FAN ONLY OPERATES IN LOW SPEED
G.E. 6000 BTU WINDOW A/C UNIT, MODEL ASV06LBS2, PROBLEM. FAN ONLY RUNS IN LOW SPEED?
  • 6,927 Answers
It is either the switch,or the motor ,the motor is designed to have the speeds in it it self,but check the voltage on high,from the switch to the motor,if there is voltage,the motor is the problem.
Posted on Jun 07, 2010
I HAVE ICE SHOOTING FROM MY A/C UNIT
If this is a window unit then make sure the water is draining all out and don't run the unit on low the slower the fan speed the the colder the coil temp which on low usually the coil temp will get down to 32 deg which will form ice.
Jun 15, 2014 | Frigidaire FAK104R1V 10000 BTU Portable...
Atwood 1522 LP furnace fan operates at one speed only
Furnace only works at one speed, high and low fan is usually used for AC. It never has had 2 speeds on furnace correct? Furnaces usually only have 1 speed, except for some home models.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
My LG 7000 BTU Heat / Cool Window Air Conditioner does not cool and the fan speed F1 will not work. Fan runs on F2. The heat works fine. Any suggestions?
You have a control board issue. You can get a new control board by Google searching the make and the model of the unit. There are several sites that sell them
May 24, 2010 | LG Heat cool Window Air Conditioner
The furnace send signal to the fan in about 30 seconds, now this fan is set in auto from my termostat, my problem is the fan is starting slowly and some time it don't start, but if I use the option manual...
Depending on the model of the furnace, the blower is either a 2 or 3 speed. When the furnace operates in heating mode with the thermostat in the auto position, the furnace starts the fan when the furnace reaches a specific temperature or after a set time delay, but it operates the fan in low or med low speed on heat mode, when you put the thermostat fan switch in the "ON" position, the furnace operates the fan in "HI" speed, the same speed used for cooling mode. You may have a blower moter that is starting to short. I would recommend having a professional replace the motor before now before it becomes an emergency in the middle of the night during a cold spell.
Oct 10, 2009 | Heating & Cooling
Frigidaire FAZ12HR2A Air Conditioner I need a spec sheet for voltage choices and btu ratings, amps, watts
give this site a try all you have to do is sign up and its free
http://homeappliance.manualsonline.com
Sep 14, 2009 | Frigidaire FAH086R1T Thru-Wall/Window Air...
Just bought 12,000 BTU unit from Lowes. It worked
you have to balance the adjustment of fan speed and the amount of coolness you set the unit for. Either increase the fan speed or lower the coldness setting.
Jun 24, 2009 | Heating & Cooling
Fan slows to about half speed when heat cycle kicks in
The heat fan speed is slower than the cooling speed. About 300 rpm less.
You may not have a problem.
May 20, 2009 | LG Heating & Cooling
Fan speed problem on GE 12,000 BTU window unit
A multi-speed, remote controlled, fan controller that only allows one speed would require a very smart person to repair it. Even the technicians don't repair them. They just replace them. This is going to cost you some parts.
Jul 22, 2008 | GE Profile ASM10AA Air Conditioner
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
