Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine oil What weight of oil should I use when changing oil?
  • 279 Answers
Normally I would say S.A.E. 30. But I would call the store you bought it at to make sure.
Posted on Jun 07, 2010
Loosing oil pressure after changing oil and filter. if engine has sludge in it what do you use to clean sludge from engine
Did you use same weight and brand as usual, or did you change to another weight/brand?
Jan 01, 2014 | 2005 Dodge Ram 1500
Change motor mounts
even weight distribution under the engine oil pan with a jack will relieve the tension of the engine weight. i recommend taking out the center nut first SLOWLY to make sure enough weight is on the jack. you can change out the roll mount/mounts without jacking up the engine.
Nov 14, 2013 | Oldsmobile Cars & Trucks
Can you use 5w20 instead of 5w30 engine oil when they reccomend 5w30
Use only the oil weight on the oil cap or owners manual if the cap does not list the oil weight. Most older vehicles called for eather 10w30 or 5w30 depending on the ambient temp. In the past 10 or so years, manufacturers updated engines for better fuel efficiency by tightening tolerances in the engines, thereby needing a lighter oil weight to provide sufficient lubrication for the parts So manufacturers started requiring 5w20 oil in their engines. I work as an Auto Care Technician at Walmart, and we will NOT do an oil change for any weight other than the recommended weight by the manufacturer. If it calls for 5w20, we use 5w20, regardless of what the owner wants. This is to avoid any possible engine oil related problems. People will blame someone else if they have a warranty issue the dealer refuses to honor for whatever reason, and it would go back to the last place the vehicle had the oil changed at. So therefore at Walmart, we follow the manufacturers recommended oil weight for all oil changes.
Mar 10, 2013 | Cars & Trucks
Dont know what type of oil to use
Put straight 30 weight motor oil in it. Not 10W30 or any multi-viscosity oil. Straight 30 weight motor oil. If you're doing a complete oil change, then you may want to use Synthetic 30 weight, which will last longer between oil changes and also make your engine last longer (but it costs more too). Best of luck to you.
James
Sep 12, 2011 | Toro Power Lawn Mower
My 1999 Saturn sl1 has an oil leakage. will changing the weight of oil help or hurt?
Only the manufacturer's recommended oil weight should ever be used in your engine.
While using a heavier weight oil might reduce the leakage somewhat, (but not much), the benefit will be more than offset by the internal damage that an UN-recommended oil weight may cause to your engine. The engine was built with certain tolerances between the metal parts, and a higher weight (thicker oil viscosity) may not be able to penetrate the spaces, causing premature wear.
In short, don't do it. Repair the leaky seal, or gasket, and only run what Saturn says you should run.
Jun 21, 2011 | Saturn SL1 Cars & Trucks
What motor oil weight should I be using on my 96 olds 88....we live where the winter temps can go as low as -10 F and as hot as 95F in the summer
5w 30 or 10w 30 during the winter. After an oil change... check your oil after 200-300 miles of use. Is the level the same? If so your weight is fine. If it drops, it's to light of an oil and your engine is now "drinking it" like fuel, move to a heavier weight. As far as Changing between winter and summer. Changing Oil weights is not bad for your motor so if the winter you go with 5w 30 and it works, great, shoot for the same during the summer. If it seems to "drink it" during the summer using this weight, go up to the next (10w 30)
That being said. Changing from natural oil, to synthetic, back to naturual , or vice versa... swapping back and forth between these KINDS of oil has been known to cause damage. so whatever weight you decide on, stick with one "type", natural or synthetic.
Feb 27, 2010 | 1998 Oldsmobile 88
What kind of oil does a 1999 Camry need?
5 qts of 5w-30.
I personally prefer MOBIL1 brand ..You can decide as per your wish..
SOME ADDITIONAL INFORMATION:
There are many grades of oil weights whichever you want to call it. Heres how it works
Oils main job is to keep the engine clean, lubed, running cool ect. The grade usually 5w20 5w30 or 10w30 ect. Theres many of them as well which can be consfusing at times. Oil weight is measure by cold and hot . For ex: 5w30 The 5 weight is when the oil is cold and 30 is the weight when its hot. The reason being is the the less the weight when its cold the easier the oil can get to the top of the engine and lube it to prevent cold engine damage. Once its heated up its a 30 weight and is thick enough to protect your engine.( most engine damage is caused when the engine is cold )You should use the proper grade that your engine calls for. Being toyota its probably 5 or 10w 30.If you live up north i would recommenda 5w30 weight.You can easily find out which grade you should use by your owners manual or under the hood on the oil cap. However there are synthetic oils as well. Synthetic oils have man made additives to help the engine run cooler, the oil is naturally slicker to help it move around easier and boost performance of the engine resulting in better mpgas well. They have alot of additives to prevent engine wear ect. One good thing about a synthetic oil is you can go longer on the oil change. Instead of the normal 3,000 miles oil change you can go 4 or 5 k. Theres also synthetic blends. Which are good too but youll have to read about it more to decide for yourself what you think you need. Synthetic oils are better for someone who travels alot or puts extreme conditions on an engine such as idling for long periods of time stop and go traffic its really good for anything to be honest.. I would recommend using synthetic if you decide to keep the car for a while. It has many benefits.
Dec 26, 2009 | 1999 Toyota Camry
I need specs.
Engine Oil SE Class SAE 10W40, 10W50, 20W40, 20W50
w/Filter Change 4.0 liter
No Filter Change 3.5 liter
Level On center stand, wait 5 min, middle of window Left side of engine case cover
Final Gear Case Oil
Above 5°C API GL-5 SAE 90
Below 5°C API GL-5 SAE 80
Capacity 0.2 liter
Level Mcy vertical, to bottom thread of filler cap hole left side of rear wheel
Engine oil and trans oil are the same
May 26, 2009 | 1998 kawasaki VN 1500 Vulcan Classic...
Oil Change
Drain engine oil and replace oil filter(your local automotive store will have a book telling you what oil filter you need to buy). You've probably been using a multi-grade 10-30 or 10-40 weight oil. Or a straight 30 weight oil. Regardless, replace that oil with one grade heavier, single-weight of oil. During warm months, use 40 weight; in the winter (depending on how far the mercury dips in your part of the country) use 20 or 30 weight. Slightly thicker oil won't hurt that worn engine, and if your battery is good, it'll turn over fast.
Jan 05, 2009 | 2003 Toyota Corolla
2005 Prius change in MPG after dealer service
What was the weight of the oil that was put into the engine when it was changed? Prius engines are VERY PICKY about the proper weight of the engine oil. Trust me. I see this quite often. The wrong weight oil can do bizzare things, and def lower your mileage. Something you can check: Take off the tube leading to the throttle body, and look down into the intake. Do you see any oil laying in the intake manifold? If so, you DEF have the wrong weight oil. This will NOT set a Check Engine light, either. Hope this helps.
Aug 19, 2008 | 2004 Toyota Prius
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
46 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
