Question about Maytag Neptune MAH5500B Front Load Washer
Water will not totally get flushed from washer. When you spin the barrel you can hear water still swishing around. There is also the odor of stale water remaining. How do I fix this?
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!%%
Posted on Sep 28, 2010
Why isn't the maytag neptune draining? when you spin the barrel you can hear water?
if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
Apr 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Stale odor within tub
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water in drum
The swish water sound that you hear in the drum is normal. There is some liquid in the drum for balancing. The washer doesnt use that liquid for laundry. The odor smell - you can get rid of it by cleaning your washer. Run empty cycle with bleach and hot water at least once a month. Also use washer cleaner - Tide recommended for a nice cleaner smell. You can get it from any supermarket.
Sep 29, 2009 | Samsung WF203ANW Front Load Washer
My Neptune MAH5500B has a terrible odor and I can hear water swishing when I manually spin the drum.
Pick up some Affresh tablets they are in the detergent isle,and the swishing you here is normal there is a liquid in the balance ring in the front of the tub that makes that noise..
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
My front load LG Washer has a mildew/musty odor. I have taken great care of this washer since the purchase in September 2004. I cannot get rid of this odor and now it is in my clothes. I have been using...
Make about 3 quarts of boiling water on the stove. Pour one cup of bleach, and a few capfuls of pine sol into the washer (just pour them directly into the washer through the front door.) Now, if you have a faucet near the washer, turn on the hot water until the water is hot- then turn it off.
Now start a "hot" load, and after the water starts to fill, pause it, and add the really hot stove water. This will raise the water level high enough to wash off all the gunk that has built up between the spinning inner barrel of the washer and the outer barrel in which it sits.
For future reference... only use HE detergent, never use liquid fabric softener, always take the clothes out as soon as possible after the load is finished, and leave the door open when you are done.
Front loaders are kind of known for this problem.
Jul 22, 2009 | LG Washing Machines
Odor, mildew around rubber ring, swooshing standing water in tub
take the tub apart and then you going to find much more mildew let me know after
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dirty water runs back into washer, moving drum, you hear it.
What kind of washer. Most washers will have a balance ring in them. This balance ring has liquid sealed inside it. So you will hear water swishing when you move it.Totally normal. If water is indeed running back into the tub, you need to pull your discharge out of the wall. It should only go in about 2 ft max. Any deeper and you can get syphoning. Dave www.washermd.com
Jan 13, 2009 | Washing Machines
I have a Maytag Neptune Front Load Washer. It spins the water out of my clothes good, but when the Washer stops and I take my clothes out, when I spin the inside by hand I can hear water between the drum...
water sound when spinning by hand totally normal, they use water as a counter balance, built into tub assy. as far as the mod/midew odors a few things things can help, first make sure youre using an HE detergent(HE detergent specially formulated for front loading machines) odors can be attributed to excessive amounts of detergent not completely broken down during the cycles, leaving the door ajar between cycles will also promote better air flow through the unit. and lastly using this product. new to the market made just for the front loading washers .
http://www.affresh.com/home.jsp
Mar 23, 2008 | Washing Machines
Incomplete water emptying following spin cycle
your pump is on its way out inside they have a small fan which pushers the water out if that is lose than the pump has to be replaced common fault
Dec 25, 2006 | GE WJRR4170E Top Load Washer
Water left in barrel (not the tumbler)
If you can't see any water and just hear it, this is completely normal. This is a front load washer and has a special cover of the inner tub basket. This cover contains some water that has been sealed in at the factory to keep the load balanced while it is spinning.
Nov 25, 2006 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
