Question about Estate EED4100SQ Electric Dryer
Clothes not dryin
You turn the the dryer on, and takes several cycles before it starts to dry the clothes. the dryer still gets hot but takes a long time to dry, takes sevral cycles.
  • 10,319 Answers
Clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Posted on Jun 06, 2010
Dryer is getting hot and turning but clothes are not getting dry
this will be filter it will need cleaning so air flow can work Billy
Sep 18, 2014 | Kenmore Dryers
Does not dry clothes, keeps turning off prior to
then it maybe the heat element.Is it getting hot and it may be the controll panel,there still could be sme lint stock some were,try using vacum hose and put in back of dryer it may free it up.
Jul 08, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
Dryer gets hot spins takes several cycles to dry fully
ahhh very common, clean clean clean inside the dryer, take the lint screen put some toliet bowl cleaner on it let it sit while you are tearing the dryer apart and clean the whole dryer vent and or change it, make sure the flap outside is not stuck shut as well...
May 08, 2009 | Dryers
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
Our maytag dryer is not drying our clothes in a timelymanner. The dryer gets hot but the clothes take several hours to dry.I heard there is a part that takes to moisture out ,if that is true could that be...
I have had a similar problem. Clothes would be hot inside the dryer after a full cycle but still wet/moist. The cover for the vent to the outside had been smashed down against the vent. Steam was still coming out but air flow was being impeded. Also, be sure to check that the flexible tube to the vent is not blocked by dust, spiderwebs,etc. Hope this helps!
Oct 07, 2008 | Maytag Dryers
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Estate EED4100SQ Electric Dryer Logo
178 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
