Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
TI 84 cant turn on
I recently tried to add more applications to my ti 84 plus (black) and when i plugged the connecting cable from my computer to my ti 84 a blue spark came out from inside the ti 84 usb port and there was smoke for a while but when i tried to turn it back on, it didnt turn on. i really need help i dont know anyone who could fix it for me and i dont have a waranty for my ti.
Sounds like your pc had a static charge that it discharged to your TI and that it fried something inside the TI. No warranty, No fix. You gotta buy a new one.
Posted on Apr 21, 2008
My TI-84 plus silver edition calculator is not responding. Whenever I press a button it takes forever to put it up on the screen or it doesn't work at all! I need some serious help with this. I tried...
Hi purzabumafu8,
You need to re-install the Ti 84 Plus OS on both calculators, ASAP!!! You can fix these problems by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the USB or, IO link ports. Then they can send you a copy of their OS, while you receive it on your Ti 84 Plus. Hopefully, your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work. Link the two calculator together through the USB or, IO link ports with the proper cable. If don't have another reliable calculator to connect too, you'll have to connect the calculator to a computer to download the OS, goto Procedure 5. If your downloading off another calculator goto Procedure 1.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Procedure1. Procedure to linking to another calculator.
On their calculator press, [2nd][Link][G] [Right-Arrow]. On your calculator press, [2nd] [Link] [Right-Arrow] [Enter] and, then press [ENTER] on their calculator too. Their calculator should say, "TRANSMIT" and, your's will say "Receiving." Then on both calculators once transfer is complete press, [2nd][MODE] to quit and, return to the Home screen. If the OS was transferred then your finished with these procedures. If your calculator won't turn on or, is locked up try the Procedure 2, below.
Procedure 2.
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 17, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 calculator lost its cover for the batteries. Since then it sometimes can't turn on or show anything when I push the button "on". But sometimes it still can work. But because I havent...
Hi twylazhangzh,
Sound like your Ti 84 Plus is really over loaded and, can't function properly. You can fix that by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84 Plus. Hopefully your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer just keep following my instructions below.
First, you need to download and, install Ti Connect to your computer. If you don't need any help installing Ti Connect goto Procedure 1.
If your computer's OS is XP or Mac and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my XP or Mac OS". Just follow Procedure 1 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
If your computer's OS is Windows 7 and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my Windows 7 OS". Just follow Procedure 3 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
Procedure 1 to installing Ti84 Plus 2.55v. MP OS
1). You can also get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, the Ti Device window should pop up and, highlight the port when found that your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
Jan 12, 2011 | Texas Instruments TI-84 Plus Calculator
When ever i turn on my ti-84, it says waiting..... PLease install operating system now.
Hi biancaaii,
You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix the problem by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS. Be careful, even a power failure during the process of installing the OS will destory your calculator.
Procedure 1 to installing the latest Ti84 Plus 2.55v. MP OS
1). You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Installing new OS
Hi mcniester,
If you need to install Ti Connect software, goto the paragraph (1) below. If you do not need to install Ti Connect software goto the paragraph (2), "Procedure to installing the newest Ti 84 Plus OS 2.35v."
1). You can get the latest copy of Ti Connect software by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti Connect software" At this Ti site under "View: Connectivity Software", Click, "the OS link that applies to your computers operating system". Next, click the Download Item, "Ti Connect software for ....OS". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti Connect software for ....OS will be download to you. Click, "OPEN" and the software will start installing. You will have to click "Next" a few times but, it install pretty fast. Once the Ti connect software has successfully installed follow the instructions to the
"Procedure to installing the newest Ti 84 Plus OS 2.35v." below.
2). You can also get the latest copy of Ti84 Plus 2.35v OS and guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.35v. OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system download to you. Click "SAVE" And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed.
Link your computer and calculator with the USB cable or Direct Black Link cable that came with the calculator. Next, drag the Ti 84 Plus OS 2.35v that you copied to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti connect" icon on the desktop. Click, "Continue" and, the new Ti 84 Plus OS 2.35v will begin to install. The Ti Device window may pop up and, click on to the port your Ti 84 Plus is using, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 84 Plus OS 2.35v will be installed.
Jan 06, 2011 | Texas Instruments TI-84 Plus Calculator
I somehow deleted all my apps on my TI-84 Plus Silver Edition how do i get those apps back?
Here is the link to the latest software for the TI84Plus /SE calculator. You will find the preloaded applications and additional ones. If you need other software visit the Ticalc.org website
To install them on the calculator, use the TI-connect software in conjunction with the TI USB SilverCable or the USB Direct Cable.
Connect calculator to computer.
  1. Open the TI Connect software.
  2. Drag and Drop the applications on the TI Connect software and let them install.
  3. Make sure batteries are good.
  4. Install one Application, then quit to permit de-fragmentation.
  5. Restart with another application.
Apr 12, 2010 | Texas Instruments TI-84 Plus Silver...
My computer won't find my ti-84
Even if you cannot connect it to the computer you can still transfer applications from a working calculator.
Here is a copy of a post I wrote to answer that question.
If you have a USB SilverLink cable, use it to connect the calculator though the I/O (round) port.
If you do not have a USB SilverLink cable, you can use the mini USB to USB Direct cable but you will have to install the correct driver for it.
I do not know what computer operating system you are running and I use Windows XP so I will describe the installation procedure for Windows XP SP3.
Install TI connect 1.6 for Windows; if your system is Vista you must install a patch available on the TI website, at the same page where you find TI Connect.
After you install TI Connect, connect you calculator to the computer with the mini USB standard USB Direct cable. Windows will detect the calculator and will try to install the drivers. You will have something that is similar to what is on the three screen captures I am inserting in the post. On the last screen, choose the TI Educational Handheld device and click next.
When Windows asks to stop installation, click continue anyway
After the installation, click finish.
Device manager will show you something like what is on next screen (TI Educational Handheld device)
Run TI Connect to verify that the calculator is recognized. Connect your computer to the Internet and click the Updates Button on the TI Connect tool bar.
Mar 22, 2010 | Texas Instruments TI-84 Plus Calculator
My TI-84 Plus Silver edition will not turn on. I have tried new batteries and everything, but it just does not turn on. Is there a way to reset it or something although the calculator does not turn on?
Here it is from the horse's mouth (TI Knowledge base)
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Oct 21, 2009 | Texas Instruments TI-84 Plus Silver...
TI 84 won't turn on. New batteries installed. TI Connect recognizes device and I installed new OS. Brightness is not the issue. Any suggestions? This is one of student's calculators. Thank you.
Sorry, answer was posted as a clarification request.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system (see below.)
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
Cant install any applications
Run the TI connect software on you computer. Turn the calculator on and connect it to a USB port on the computer. Before you drag and drop applications on the TI connect software window, Click on one of the icons (TI Device Explorer, TI Device Info, TI Screen Capture). Two new smaller windows pop up, the one on top has the title Select TI device. If in that window it recognizes your Calculator Model, you click on select and OK, and you are ready to communicate with it.
If on the other hand, it fails to find your calculator on any of the 3 or 4 communication ports (COM3, COM4, USB1, etc.) then you click on the communication setting and in the drop down lists
Sep 03, 2009 | Texas Instruments TI-84 Plus Calculator
TI 84 Plus
Connect to your computer and turn on the calc.
Drag and drop a file to the TI Connect Icon and it will ask you, eventually, where you want to send the file....It should find your calc.
Sep 04, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
218 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
