Question about GE Profile PDW8600J Built-in Dishwasher
The door on my PDW8680J00SS suddenly won't open. latch may be broker, but I can;t open the door to see what's wrong. How can I get this dorr open if the latch is broken?
  • GE Master
  • 12,061 Answers
Http://appliancejunk.com/ge/dishwasher/31-9137.pdf
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Hi please find above, your service and repair manual., top, the other link is for a DIY self help Dishwasher service and repair site. This shows you how to do everything you need.
Posted on Jun 06, 2010
Nissan door latch
Bhi if you pull the door Handel to the open position and hold it there take a screwdriver and lift the latch to the open position if it's rusted spray with wd40 and let it sit for a while first good luck
Nov 30, 2017 | Cars & Trucks
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Front door panal removal when door will not open
This is not an easy fix. If you can roll down the window you are going to have to look in the window slot towards the latch. See if you can tell if it uses rods or cables. If it is locked, you have to get something to reach the latch and unlock it. You might consult a locksmith
Jul 22, 2012 | 2008 Jeep Patriot 2.0
I broker the handle of the machine (washing is Finished) cant get the door open for Hotpoint washing machine
Since the door is broken try to break the latch, without damaging the rest of the machine. Will need a screwdriver and drill, to remove the plastic door. Don't drill into any glass or metal.
A new door will need to be sourced.
Sep 08, 2011 | Hotpoint WMA30 Front Load Washer
03 golf gt tdi driver door very sticky on opening from outside and no problem from inside It has failed nct and more recently when I press the key once it unlocks drivers door and when pressed again it has...
Try spraying the latches with a penetrating lube. Get it in the latch itself and rotate the can so it covers as much of the latch as possible. Then work the doors open and closed a few times. Repeat this process 2 or 3 times. Dorr latchs can use some lubriation from time to time, especially the doors not commonly used. Once they free up then go back in with a spray lubricant like WD-40 to keep them free. Hope this helps.
Apr 29, 2010 | 2002 Volkswagen Golf
Passenger door lock jammed
Your door latch assembly may be compromised. It could be rusted, the electric solenoid (if it has one) may be seized. Or the rods from the key are bent. Are you using th key in this door regularly? If not, the tumblers in the lock may be seized. Spray some WD-40 in the lock where the key goes, and jam the key in & out repeatedly, and retry. Remove the door panel & spray the interior of the latch, also. Hope this works for you; or, you are going to need new latches.
Aug 24, 2008 | 1997 Toyota RAV4
DOOR WONT LOCK KENMORE ELITE HE4T
Before removing try some WD40 spray on the door mechanism, not on door.
Aug 23, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool model WBP36800 range (about 15 years old) starts a self cleaning cycle without any operator input. What is wrong. Thanks Cliff
souds as if a monitor switch has gone bad on your self clean latch mechanism.its continuing to lock and unlock door because the switch that tells the control that the dorr is unlkocked has gone bad and as a result continues to rotate constantly
May 09, 2008 | Kitchen Ranges
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile PDW8600J Built-in Dishwasher Logo
63 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
