Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I have a honeywell digital programmable thermostat in my home, it will not go any cooler than 74 degrees...i have tried to press the buttons every which way but it will not go any colder.
    Guru:
  • Honeywell Master
  • 587 Answers
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Jun 08, 2010
Just moved in yesterday and the Honeywell thermostat is not working properly. the down stairs has diffent kinds but the up stairs rooms have the Honeywell thermostat. we set the temp. to 60 degrees but it...
Sounds like the programming on your thermostat needs to be reconfigured, but I need more information like the Honeywell Model number which can be found behind the front cove, but becareful to unsnap the t-stat properly not to damage the pins that connect t-stat to its base.
Jul 25, 2011 | Honeywell Programmable Thermostat Heater
My honeywell t87n is adjusting the heat setting by
This sometimes happens over time with some digital thermostats. The easiest solution is get a toothpick and hit the reset button. From there just set it as you normally would. That should solve your problem.
Hope this info was helpful to you. Good Luck!
Jan 29, 2010 | Honeywell Heat/Cool Thermostat
Th8000 does not match another thermometer inside home
Is the thermostat mounted near a lamp or other heat source?
Is the wall warm from ducts in the wall or a refrigerator on the other side?
The thermostats are usually pretty accurate. Most times I find some other influence on the thermostat causes the problem.
The Honeywell 8000 series also has a feature accessed through the installer setup menu, that will allow the temp display to be changed + or - 8 or 9 degrees.
Check the manual or Honeywell's website for a .pdf if you need it.
Hope this helps.
Matt
Jan 11, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
243 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
