Question about Ruud UBHC Air Conditioner
Ruud upne-042jaz fan not starting
The fan motor turn with ease.
    Scholar:
  • 45 Answers
If the fan motor is not starting it may be the capacitor located behind the electrical panel on the outside unit. These are relatively inexpensive and easy to change. You can disconnect the power to the outdoor unit and remove the capacitor. Take it to your local HVAC wholsaler or contractor and have them check it. If its bad it should run you 20 to 30 dollars to replace. If it is not the capacitor then it may be the fan motor. If the blade turns easy it means the bearings are fine. One of the windings may be open thus making it able to turn but not run when power is supplied. I think this is a heat pump and there may be a control board on the outdoor unit which may control the operation of the fan. I have not found a wiring schematic for the unit yet. Once I find one I will let you know. The problem listed above is very comon and inexpensive for you to fix. If it is something other than the capacitor, I would call you local NATE certified technician and get her looked at.
Posted on Jun 07, 2010
Where can I get a service manual for a Ruud Ac model UAPC-42JAZ
Go to the following web address:
www.servicemanuals.net/‎
Oct 07, 2014 | Ruud Heating & Cooling
What size capacitor does the out door fan motor require on a RUUD Model number UPMC-042JAZ
call your local ruud dealer and have him cross reference model number or look on fan motor itself, if original then cross reference ok, but if it has benn replaced look on the fan itself
Jun 19, 2014 | Ruud Heating & Cooling
My outdoor heat pump will not come on. its a upne-042jaz heat pump by rheem.how can i determine what is wrong?
With out a meter it hard. Check to see if you have power out side in the unit, if yes cycle the unit off and back on with the stat. this will reset the high pressure switch lockout relay, if after the delay nothing, check for a manual high pressure reset, if a manual there will be a button at the top of the switch, press hard while holding the rest of the switch. If this works then you either have a bad fan motor or the outdoor coil is dirty, Take the garden hose with a nozzle to it use, use a solid stream use a much pressure as the fins will take without bending them start at the top and go across working down,
Jun 30, 2011 | Heating & Cooling
WHAT SIZE UNIT IS A model # UAKB-042JAZ SERIAL # 6953F300414316..HOW MANY TONS IS IT...
They are: Height:19in X Length: 40-1/2in X Width: 27-5/8in
You can also check the manual here:
http://www.adamsheatingandcooling.com/ruud/ruud-ac/uakb/UAKB-specs.pdf
It is located on page 6.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Ruud UAKB048 Air Conditioner
We have a RUUD AC unit, model number UAMB-042JAZ. ...
Those are the low voltage wires from the thermostat and transformer. Yes he can just match up the colors and splice with wire nuts or something else to hold the tight. If the transformer got shorted out during any of this it may need to be replaced. Hook them up and if the unit runs, then no problem with the transformer.
May 21, 2010 | Heating & Cooling
I am trying to get an electrical schematic of my RUUD 3.5 Ton condensing unit UAKA-042JAZ. The one that is attached to the inside of the unit's cover is not readable. Where can I get another drawing to...
thers 2 sides of power in the entire unit besides the 24 volt control wires! what are you trying to make run? theres a fan and compressor, both operated off the same contactor!!
Aug 22, 2009 | Heating & Cooling
Power outage last night now my RUUD High Achiever AC Unit model# UPNE-048JAZ will not work
Power surge may have taken out your control board (in the furnace, does the fan work?), possibly the transformer (in the furnace) or possibly the capacitor (in the A/C). Call a professional.
Daily reset of outside unit
I have the same unit and was having the same problem. My brother works on A/C's and told me that the coils most likely needed cleaning from the inside out because when they are clogged with a lot of debris the system will overheat and cause that switch to trip and so far it has worked. What you need to do is turn the main breaker off to the outside unit first then take the four screws out of the top of the unit, use a flat head screwdriver and lift the fan it's self up out of the carefully taking caution of the wires going to the fan, then take the garden hose with a spray nozzle and wash the coils from the inside spraying through the coil to the outside and then wash the louvers off of all the debris and this should help.
Jun 29, 2008 | Ruud UAMB042 Air Conditioner
Ruud UBHC Air Conditioner Logo
359 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
