Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
Posted on Apr 10, 2008
Install siruis sportster in 2007 murano
I would like to install my sportster in my 2007 murano. Do I need to get to the back of the radio? If so, How do I get to it?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
109
Points
Have no plugs in back of the stereo
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Apr 27, 2008
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
8467
Points
19
No need to get to the back of the radio to connect this unit as it will broadcast over an fm frequency. But if you have have issues with static, you may need to install an FM Direct Adapter which plugs into the back of your car stereo where the antenna plugs in now. Professional installation is advised, but not required. If you need more specific help, let me know.
1helpful
2007 Nissan Murano. "SLP" and "VDC off" lights came on.
Question edited for clarity.
Question moved to model category.
Needing an alignment wouldn't cause that. The lights may be caused by wheel sensors not being connected back up properly. Or this, battery disconnect.
https://www.nissanmurano.org/threads/vdc-off-slip-abs-lights-on-after-replacing-battery.224511/
Running rough may be due to them disconnecting the battery, and there is a relearning process to go through. Take it back to them.
1helpful
I want to know if the gearbox and BCM unit of 2007 Nissan Murano is replaced, why is it still in limp mode?
Reset codes. one way is to disconnect battery overnight, but that will also require resetting radio security code, You will need a repair manual for resetting error codes.
2007 Nissan Murano Static in Radio
I have the same problem with a 2010 Murano. It doesn't happen in the winter like you said. It has to do with the air conditioner or with humidity. I just drove today with the AC off and the problem went away. It could be a power problem or a moisture problem.
5helpful
2answers
Back up camera
I agree with Mike. The same thing happened to my 2007 Murano after I needed to get a battery jump -- my screen went black, no back-up camera, couldn't turn on radio or HVAC.
Brought it into my dealership who changed the battery, then they wanted to run a diagnostic (around $105/hr). I asked about the fuses, and thankfully, as it turns out, it was the "back-up battery fuse." Just paid for the battery and labor for that, and the fuse.
2helpful
2answers
Radio skipping
Take it to you Nissan Dealer and tell them. If your 36k miles or under it is still under warranty.
Need to disconnect XM Tuner
the xm receiver is in the left rear quarter of van looks like between wheel well and rear of vehicle this is drivers side
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
