Question about InFocus Projector Lamp for IN24+, IN26+
I got a new lamp for my InFocus IN24+ and it shuts down in like 10 minutes!!how do i open it up to get to the filters??and there are filters because it says on the screen check filters before unit shutdown
    Novelist:
  • 130 Answers
THere are no filters for the IN24 its a DLP and most dont use filters. Ive had mine apart and i dont see any filters in mine.
Posted on Jun 30, 2010
Resetting the lamp timer on an infocus in24 projector
To reset the lamp timer on an in24 go to settings, then select Service. The option to reset lamp hours should be in this menu.
I hope this helps!
Projector Lamps Projector Bulbs Projector Parts Projector Repair Servcie
Jun 04, 2014 | InFocus Office Equipment & Supplies
Projector will not power off or display a picture
You have to double tap the power key to shut it down. The screen should go dark right away but the cooling fan will run for another 1-5 minutes.
Oct 19, 2010 | InFocus IN24 Multimedia Projector
Projector keeps shutting down every 20 minutes. Could it be the fan or the bulb? or something else?
look at the lamp and check to see if there is foil tape over the seams on top of the lamp. The top is the side under the top cover of the lamp when installed. If the foil tape is absent, then the heat escaping from the seam is triggering the thermal sensor in the lamp housing causing the premature shutdown. If your lamp does have tape on it then your lamp is probably going bad.
Aug 05, 2010 | InFocus IN24 Multimedia Projector
IN24 Multimedia Projector: Orange light bulb light came on....does this mean ...
if it runs for a few minutes before shutting down, it could be the lamp. check to see if the seams of the lamp that are closest to the underside of the top cover have foil tape covering the seams, if not then this has been known to cause premature shutdown.
May 17, 2010 | InFocus IN24 Multimedia Projector
Can the filter be changed on an InFocus IN24 projetor? If so, how do I do this?
there are no replaceable filters. just blow the dust out of the projector with canned air
Dec 03, 2009 | InFocus Projector Lamp for IN24+, IN26+
Screen goes blank and projector shuts downafter about 10 minutes (IN24 In Focus projector)
ballast/ power supply issue. you'll need to send it in to an infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 28, 2009 | InFocus IN24 Multimedia Projector
Replace bulb in housing for Infocus IN24.. i want instructions how to remove old bulb from housing.
1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
Nov 09, 2009 | InFocus Office Equipment & Supplies
Infocus IN24 lamp not lighting up
MAKE SURE BLUB WIRING IS THE SAME AS OLD BLUB, IN24 AND IN24+ WIRING IS DIFFERENT IN CONNECTOR.
Mar 20, 2009 | InFocus Projector Lamp for IN24+, IN26+
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
InFocus  Projector Lamp for IN24+, IN26+ Logo
313 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
