Question about Sharp PG-B10S LCD Projector
I was using the my projector when it just shut off. The bulb only has maybe 70 hours on it. The projector was hot, but this wasn't unusual from my previous experience with the projector. I unplugged the projector, let it cool, checked the bulb and the filter. both appear fine. I vacuumed the other filters, still no power. the light on standby isn't even on. Did I overheat and fry a circuit board?
Sinista
  • 6 Answers
SOURCE: Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Posted on Jul 10, 2008
  • 17 Answers
SOURCE: Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
Posted on Jul 17, 2008
SOURCE: No power indications
Remove the six screws from the bottom and 2 screws in the back that hold on the top cover. Once you have the top cover removed you will see a small round red button on the front of the unit. Press this button in; it should not pop back out. Put cover back on and plug it in.
Posted on Dec 06, 2008
projdoc
  • 2237 Answers
SOURCE: Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Posted on Jul 23, 2009
SOURCE: After 20 minutes of use picture shuts down. (Sharp XR-10X)
This projector along with Sharp cust service are very poor quality. I have 2 of these. Both blow the bulbs with 400 - 500 hrs on them. Then Sharp refuses to warranty bulbs. My last bulb blew with 2 days on it & only 6 hrs. Sharp still refused to warranty the bulb (By the way I only use factory replacement bulbs from Sharp). Very poor cust service. They say "bulbs are not a warranty item" Never again will I buy Sharp. If you read all the post on these projectors everyone says the same thing. Sharp knows there are bulb problems, but just passes the problem to the customer.
Posted on Jan 07, 2010
My argus 300 projector bulb blew new one won't work
yes could have been a power surge at the time, or fan cooler packed it in, the internal housing inside the Projector would have been too hot with the bulb inside it cooling down without the fan, i would double check all parts near the lamp housing and check to see they have not melted or burnt, also worth checking the fuse as well should be a T-250 Fuse bulb
Apr 23, 2017 | Argus Vintage Cameras Inc Projector Model...
JVC DLA-RS1U Projector turns off
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Apr 17, 2012 | JVC DLA-RS1U Projector
I have a BenQ PB 6210. After switching it on, it first displays that the lamp has run 2001 hours and should be replaced. After this window disappears, it takes maybe 2 seconds and the projector shuts...
Hi cholthusen,
Please be informed that the average lifespan of a projector's lamp is around 2000 hours. The light bulb is almost certainly the problem. The best solution would be to change the bulb. The easiest way to do that is to change the lamp assembly (fresh bulb is in the new assembly). You may also try resetting the unit. Turn the unit off, then physically remove the power cord. wait for about 10-15 seconds then start it back again. If this did not work, please replace the lamp.
Hope it helps.
Thank you for using FixYa.
Jun 23, 2011 | BenQ PB6210-DLP PROJECTOR XGA Multimedia...
Infocus Projector IN83 is overheating and shutting down every 20 minutes or so. Talking with online assistance suggested that I replace the bulb so I bought a $200 new bulb assembly and it has already...
I had the same problem so removed the bulb which is very easy, only 3 screws, found the wire mesh inside was covered in dust so vacuumed using a brush head attachment, removed all the dust & did the same to all the external vents too. The projector now runs smoother, quieter & does not over heat after hours of continual play. Hope this helps, Chris
May 20, 2011 | InFocus IN83 Projector
When we turn the projector on it gets hot then it shuts off.
check that fans are running and screens/ filters for fans are clean and free of debris
also what are hours on bulb - if bulb is too old that could be causing issues also
Mar 21, 2011 | HP VP6310 Multimedia Projector
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
Projector turns on and works for about 2 minutes, then shuts off
You may have to reset the bulb hour counter. Go thru the setup menus and see if you can do it from there. Infocus projectors make you jump thru the hoop.
Aug 30, 2009 | Mitsubishi XD480U Multimedia Projector
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
Sharp PG-B10S LCD Projector Logo
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
