Question about MTX Thunder Elite 801D Car Amp
Wont power up
I have an elite 801d that wont power up. I dont have a cap., i just run from battery to to the amp. The fancy lights flash, but the amp itself wont power up. neither the protect light or the power light comes on. is there something special you have to do to get this to work
  • 518 Answers
Providing you also ran a ground direct from battery, you need a trigger wire from stereo i usually run off power antenna wire.Some stereos have a seperate amp or trigger wire already coming out you just need to run it to amp.
Posted on Jun 06, 2010
We have a Kenmore Elite 79577554600 Refrigerator. The temperature display is freaking out. The numbers keep changing, lights flashing on and off, temperature counting down from 44.
It is running in "store-demo" mode. Fancy light-show, and the compressor turns off (bad!)
Hold down the right-most two buttons (Ice and refrigerator temp) for about 5 seconds. I think the right-door needs to be open for this to work, but not sure.
This will activate the fridge once again.
Dec 24, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Hello, i have a nitro bmw 486 amp. i use it to power my 2 subwoofers in my trunk. its a very good amp and sure does its job, but randomly the light will turn red, which means protect, and my subs will shut...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty D .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-lv2kkrmxrai4iihdvw4m3np2-1-0_0.jpg
Jul 31, 2010 | Nitro BMW-486 Car Audio Amplifier
Mtx 801d amp turns on but no bass just high pitch sound sub is fine
if theres a switch on ur amp that says LPF Full or HPF put it on LPF for low pass frequencies
Mar 16, 2010 | MTX Thunder 801D Car Audio Amplifier
Amplfier mtx rfl404 goes into safe mode when playing at load volume after 10 mins
you might need to turn the amp down and get some better wires to carry the load. when at lot of juice is being tranfered you need good wires to hold it
Mar 14, 2010 | MTX Thunder 801D Car Audio Amplifier
I turned my system up all the way for about 2 mins and the mtx 801D amp stop working, it lights up and the fuse is not blown but it won't power the subs.
had a friend with same problem...paid me to look at it and well...amp was just overheated or short/loose ground.
Jul 02, 2009 | MTX Car Audio & Video
Inspiron 1100 will not boot up-suspect power problem
I would hook it to an external monitor first to see if the screen is blown.
If it comes on, keep pushing F12 to get the diagnostic screen.
Run a complete test, it will give you error numbers.
Jun 22, 2009 | Dell Inspiron 1100 Notebook
Jl audio
If the amp was hot, it probably has a serious problem. You should have it checked out by a qualified tech. Don't continue to use it. More serious damage could occur.
May 29, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
Apr 05, 2008 | Dell Latitude D600 Notebook
Audiofonics
i would go with the 801.And ithink u meant the 4501 not 4051.Both super power amps. competition stuff.your woofers are 4ohms dual voice coils.so you can series the coil on eaach woffer and use the two channels on the amp.they play at 2ohms.I think if you drop it down to 1 ohm you really be taxing you alternator that is series power.Yioou would need a special alternator.Even with them running in 2 ohms you better hav eat least a 2 farad cap.OR two batteries.. ! more thing don 't pump it up with window s closeed .you'll pop them.serious dbl. you be pumping.I'm jealous.Rating please and enjoy.
Feb 09, 2008 | Audiofonics ADF-272 Car Speaker
WONT STAY ON
check your batteries...sometimes cheap batterie or regular batteries do the same to mine...you may need to spend the little extra and purchase batteries for a digital camera ect....good luck
Sep 26, 2007 | Vivitar ViviCam 3780 Digital Camera
MTX Thunder Elite 801D Car Amp Logo
171 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
