Question about Sewing Machines
How do i get the thread to properly come up through the bottom - bobbin is already threaded
  • 736 Answers
Pull the thread thru the needle about 3 inches .. lift the foot .. place the thread under the foot exiting toward the back ..hold on to the end of that thread ... turn the sewing machine by hand one turn .. that will loop the top thread around the bottom thread .. now use a screw driver or stick or what every you have. slide it under the foot and out the back .. both threads will now be sticking out the back .. pull a little out (you may have to turn the machine a little to release the threads) .. now when you see both threads sticking out the back under the foot you are ready to sew ..
Posted on Jun 07, 2010
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
My top thread has large loops on the bottom, bottom thread is normal. I have tried to adjust the tension but it does not help
The bobbin also has tension adjustment. Take bobbin out and try making it tighter. Also make sure thread is threaded properly on bobbin.
Mar 02, 2015 | Sewing Machines
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
Machine won't stitch
If by "won't stitch" you mean that the top thread will not pick up the bottom thread, make sure you have the needle threaded properly. If the machine is a top loading bobbin, the thread goes in the needle from front to back. Same if it's a side loading bobbin (bobbin faces you as you sew). If it's a front loading bobbin (bobbin faces left of machine), the thread goes in the needle from left to right.
Oct 12, 2014 | Sewing Machines
Bobbin thread won't sew in
I think you will not bobbin thread winding properly and bobbin tension. Otherwise you put the correct size bobbin ,case and check the timing.
Jan 05, 2014 | Sewing Machines
Keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
The thread from the bobbin is all loopy in the stitches
Always thread the sewing machine with the presser foot up.
This allows the thread to properly enter the tension control.
If the thread is not in the tension control as it should be, when it connects with the bobbin thread it is not tight enough to form a proper stitch.
The bobbin gets the blame because it feeds from the bottom.
Mar 10, 2010 | Janome Sewing Machines
Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Nov 13, 2007 | PfaFF Quilt & Craft Pro 7530
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
