Question about Hayward Pool Products HAYWARD 1.5 HP 2 SPEED SUPER PUMP - INGROUND POOL PUMP -
Recommended outlet ampage - Hayward Pool Products HAYWARD 1.5 HP 2 SPEED SUPER PUMP - INGROUND POOL PUMP -
  • 3,740 Answers
Is the pump 120V or 220V? 120V you will need a 20 A breaker. 220V you will only need a 15 A breaker.
Posted on Jun 06, 2010
Can bad fuse cause buzzing when on and what size fuse to replace
no
sounds like interference or feedback, the fuse is nothing to do with anything it is just a weakling designed to blow in the event of an overload.
Do not change the fuse above the recommended size, this would allow too much electricity to flow in the event of a problem the higher ampage could cause more damage than would be the case if you left the fuse be
t
Jun 29, 2015 | Audio Players & Recorders
How do find out what ampage my altenator is
Have a dealer run your VIN # on how it was built
Then you know what alternator to install
That # you gave us-- is of no use
If you take the alt to parts store they may have a way of
telling you what it is
Dec 07, 2012 | Cars & Trucks
Would like to change power supply to 12 VDC On Samsung LE37C580 37" LCD TV
The only way to do that is to buy a DC to AC converter...that is if you want to run your tv off of 12Volts DC. The converter converts the DC to AC so you can just plug up your set to the converter. The higher the ampage the better the results. Match your ampage of your tv to the converter ampage output. Just do a google search for "DC to AC converter". There are many availiable and many different prices. It is not practical to change the TV to receive DC voltage.
Jun 16, 2011 | Samsung Televison & Video
2005 power window failurefo sport trac explorer
well lets start at the begining - if none of the windows are working take out your owners manual.
find the fuse and relay guide - look for the power window fuses, pull them out and check if they have been fused - like a light bulb burned out.
if so replace them with ones of the same ampage - the number printed on the fuse or ampage set in owners manual which ever is higher do NOT go over ampage in owners manual.
if fuses are ok look for the power windows relay - with engine off but key on have someone operate window switches and you listen and feel for relay clicking which means it is energizing.
Now with out any knowlege of how to use a volt ohm meter or understanding of DC electric it will be near impossable to instruct you on pulling the relays and testing them; test the drivers side window switch for power by taking the door panel off. testing the window motor for voltage going to it when the switch is in the up or down position and a common falure point in older cars the wires running from the door frame through to the door.
good luck
Mar 25, 2011 | Ford Explorer Sport Trac Cars & Trucks
The other morning I woke up to a fridge with no power. I'm not sure if the problem is the fridge or my oulet. The only reason I do not know for sure is that I cannot get my fridge out of where it is. So I...
The plug will have to be gotten to in order to test the refrigerator properly. Do check the right ampage fuse is fitted 13A in the UK.
There is no reset button on your model.
Jan 12, 2011 | Amana AFB2534DE Bottom Freezer French Door...
1990 Caravan: it keeps falling off...
How many miles...could be the fuel pump sock is dirty. Check for ampage from the data terminal located close to the relays. You will need a DVOM and have it on ampage test. It plugs into terminal #1 & #6. #1 isn't too hard to locate sine #2 is empty and #6 is on the back of that terminal which is on the same side of #2 terminal. The ampage shouldn't be no more than 4.5. If it is pulling close to 7amps, The pump is going bad. Another way to test it is put a fuel pressure gage on the schader valve by the throttle body. Place it up by the windshield so you can see if while you are driving and see if drops off while this issue is happening. A good reading should be at least 37psi. Make sure that you have a new fuel filter on which is under the vehicle, passenger's side.
May 16, 2010 | 1990 Dodge Caravan
Wiper fuse blows as soon as you insert one
first....be sure the fuse is the right ampage. second...if the ampage is correct, and it still blows, do the following. Disconnect the ground-side of your battery. Attached test lamp to ground-side of battery. Take probe end of test lamp and touch anypart of the motor body frame. If the test lamp (DOES NOT LIGHT UP), you have an electrical short. Recommend OBD (On-board Diagnostic) analysis test.
Apr 25, 2010 | 1998 Subaru Forester
Have lost manual. I need car charger for Mio P550 but Mio no longer making. Have purchased Scala AC Travel Charger Part No; SEL15305 (Input voltage 100-240VAC, 50/60Hz) and end is right but not sure if it...
The important thing is the ampage. If you have your old car charger check the ampage output. A higher amp rating charger will be ok as the p550 will only draw the current it needs. The voltage you listed sounds like a house charger not a portable car charger. cars run at 12v and the output should be something like 5v dc - 1amp (normally anyway).
Feb 18, 2010 | Mitac Mio P550 GPS Receiver
My power source is not doing anything! I've checked my cord, and it has full power, but I'm getting no "juice" from the system when it's plugged! I'm going to replace the power source for this Acer, but...
The PSU must be EXACT or it will damage the unit. Also the "Polarity" of the plug MUST be correct too. That is why it is always best to get the Acer one... But in saying that usually they are usual 9 - 12 volts at 4 - 5 Amps.
Jan 26, 2010 | Acer Aspire L100 PC Desktop
My dryer doesn't appear to be drying as fast as before.
Most times this is because there is a restriction of the air flow leaving the dryer exhaust pipe. This will cause a buildup of heat and cause the high limit to turn the heat off. If clearing the exhaust pipe of crimps, dust or clogged line does not help then let me know. Thanks, Sea Breeze
May 27, 2009 | Maytag Dryers
Hayward Pool Products HAYWARD 1.5 HP 2 SPEED SUPER PUMP - INGROUND POOL PUMP - Logo
95 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
