Question about Amana DLE330RAW Electric Dryer
Power wire troubles
I need a wiring diagram to connect the power cable to the dryer. model number dle330raw
  • Amana Master
  • 3,740 Answers
See page 7 of this .pdf manual:
http://www.servicematters.com/maytag_library/docs/RS3200007R0.pdf
It will show you both 3 and 4 wire connections for your dryer.
Thanks for using FixYa.
Kelly
Posted on Jun 06, 2010
No heat
Hello there:
There's no heat If your dryer doesn't heat, check these: Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block
May 13, 2010 | Amana DLE330RAW Electric Dryer
My amana dle330raw stopped heating, I think it is the heating element, where is this located?
take off the bottom panel and on the left back wall you'll see the heater part number Y503978 it's around 52 bucks.if you didn't know where the heater was how do you know it's bad?if you don't have a meter go buy one for around 20 bucks before you start buying parts that you don't need.you could be right it could be the heater but why guess,unplug the dryer,pull one of the wires off and read out the heater to make sure,also do you have 240 volts at the block where the cord connects to the dryer,i've found dryers where the people had a bad fuse and only 120 volts was going to the dryer so start there and check things out with the meter,if you need more help let me know,good luck
Feb 20, 2010 | Amana DLE330RAW Electric Dryer
The dryer had,a 4 prong plug,but my plug in,is 3 prong,so I put my old cord on it,the dryer spins but doesn't heat.do I need too switch plug in?
The following link explains how to correctly install a power cord on your appliance:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
The main difference is how the Neutral (WHITE) wire and Ground (GREEN or BARE COPPER) wire are terminated on the terminal block in the back of the dryer:
- In a 3-wire configuration, these two wires are connected together via a ground ******** the terminal block.
- In a 4-wire configuration these two wires are independent of each other are NOT terminated together. Neutral is terminated at the terminal block and ground is terminated to theequipment cabinet via a ground lug.
NOTE: Newer homes built after the year 2000 REQUIRE a 4-wire configuration to be in complaince with the National Electric Code. In addition, some newer appliances may not work correctly without a 4-wire power cord. You want to refer back to your installation instructs to verify your power requirements.
If you have any questions, please let me know. I hope this helps you.
Dec 13, 2009 | Amana DLE330RAW Electric Dryer
Wiring
It should be inside on the front cover of the dryer. I know, it's a pain to remove and get to. Not hard, just time consuming.
Apr 21, 2008 | Amana DLE330RAW Electric Dryer
Frigidaire dryer timer wires
I need your model number to look up the wires
Apr 03, 2008 | Frigidaire FDE336RE Dryer
Replacing a pigtail
You hook the Red and Black wires to the gold colored screws on the dryer, and the white wire goes to the siolver colored screw. The Green wire goes to the Body.
Sep 19, 2007 | Amana DLE330RAW Electric Dryer
Amana DLE330RAW Electric Dryer Logo
141 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
