Question about Pioneer AVIC-D2 In-dash Car Audio Stereo CD player with navigation and 6.5" video screen - Free UPS ... Car Video Player
What wires need to be hooked up to the positive wire and which ones for negitive
    Sergeant:
  • 356 Answers
Red = positive to battery
Black = negative/ground to body
solid colored wires - positive speaker
while lined wires = negative speaker
Yellow = starter switch
Posted on Jun 07, 2010
What wires go to my positive and negitive side on my battery on my 03 yamaha r6
Positive wire is red whereas negative can be either black or brown.
Hope this clarifies your doubt.
Aug 14, 2014 | 2003 Yamaha YZF-R6
I just got my subs and amp i have my amp wired up but what do i need to hook the amp to the sub?
you need speaker wire. you will hook one end to the negitive on the amp and one end to the black(negative) spot on the speaker. then hook one end of the other wire to the positive on the sub and the other end to the red(positive) spot on the speaker
Aug 27, 2013 | xXx XBX1200 Car Speaker
I have a brand new logic soundlab tx1002. it was hooked to a brand new radio and new speakers. When turned on, it is in protection mode. you get a popping sound from the speakers. we have checked all...
first disconnect one wire at a time, making sure the power is off. then connect power and check to see if your speakers are making the popping sound. when you do your speakers, make sure you disconnect both positive and negitive of each speaker at one time. when your amp goes out of protect mode you will have found your suspect wire. then trace to the issue. it could be as simple as crossed over possitive and negitive wires
cheers
Jan 11, 2011 | Logic Soundlab LSX2600 Car Audio Amplifier
Is the black wire negitive and white wire postive
The Black wire is the Hot or positive wire and the White wire is the nuetral or negative wire.
The green wire gets hooked to the frame or any metal part of the dishwasher...usually there is a green screw inside the little box where the wires hook up
Heatman101
Apr 15, 2010 | Bosch SHU9925UC Built-in Dishwasher
How do i hookup two 12" championship series pioneers wit 2 positives and two negitive for each speaker
Hook up one positive wire to the right side output of your amp, do the same with the negative wire for that speaker, right side out put. Then repeat the same for the other speaker, but on the left channel.
Mar 28, 2010 | Pioneer TS-SW2541D Car Subwoofer
12 volt system
The wires you have are white for common, 1 black for slide in, 1 black for slide out, and green for ground. Verify the direction that each of the black wires moves the slide before wiring. You will need a 3 position switch also.
Jul 03, 2009 | 2001 Chevrolet Silverado 1500
Connecting the wires to my sub
at 4 ohms you go from positive with the dot to the negitive with no dot and then conect the other two together and that is for 4 ohms. For 2ohms positive with dot to negitive with a dot than connect the other two together. try that shut down everything befor you start working on it so you dont blow fuses on amp or deck or under the hood. try one than turn it up see how it sounds than try the other way to see what sounds best.Contact local dealer if you are still haveing problems.If not rock out and crank that bass .
Mar 03, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
HOOK UP MANUAL ELEC FAN SWITCH TO DASH
theres two was you can do this. First is to go and get a universal electric fan controler form your local auto parts store there about $30 and the come with instructions its realy easy to do. It will turn the fans on/off only when needed. Second way is to just find the positive and negitive wires fom the fan and hook the positive directly to power with a fuse in line. next hook up a on/off switch inline with the negitive wire fron the fan to one terminal on the switch and then a wire from the other terminal to a good ground. then run the wires thought the fire wall and find a where you want to mount it. the down side is you have to rember to turn on the fan when your driving.
Jan 25, 2009 | 1998 Jeep Cherokee
My amp wont power both subs the same
you most likely mess up you wiring... im not sure what ohm resistance your subs are, but if its 2ohm or 4ohm you wire straight foreward one sub all positive wires to left positive, all negitive to left negitive, and the same with sub 2 to the right terminal. BUT if your subs are 8ohm then wire it with all positives from both subs to LEFT positive and wire all negitive wires to RIGHT negitive... and see if that helps and good luck!
Jan 12, 2009 | Pioneer TS-SWX310 Car Subwoofer
Don't know which is the positive and negitive wires
To be honest, it really doesn't matter - the speaker is just a resistor electrically, which is not a polarized component. You can hook either wire up to either side and you will get the same sound. In any pair of speaker wires, do you have one with a stripe and one without? If so, the striped wire is the negative wire. If you have a light colored wire and a dark colored wire, usually the darker one is ground (ie, yellow wire and purple wire in a pair for example - the purple would be the negative and the yellow would be the positive). But honestly it doesn't really matter which one goes to which terminal - electrically they have no real difference. If you hook them up "backwards" from what the factory intends, when the speaker plays, it'll pulse inward rather than outward from its mounting frame. It'll move the same distance with the same velocity however, so it'll create the same sound.
Sep 27, 2008 | 1994 Ford Club XLT
Pioneer AVIC-D2 In-dash Car Audio Stereo CD player with navigation and 6.5" video screen - Free UPS ... Car Video Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
