Question about Honeywell Programmable Thermostat Heater
T8011r thermostat doesnt have a display, fuse is not blown out and it suddenly stopped working
  • 674 Answers
Here is a link for the owner's manual. It gives several suggestions for the cause of the display being blank. Check those and let me know if that helps.
http://www51.honeywell.com/pacific/common/documents/T8000C_T8001C_T8011.pdf
Posted on Jun 07, 2010
I have Honeywell T8011R programmable Thermostat. Turn AC on last night for first time...working fine...came back late morning to find display and fan off. Check circuit breaker...on. I took it off and...
Hello, first you must verify if you are getting 24 volts to the tstat at the secondary side of the transformer, if not you have a bad transformer. If you are getting 24 volts then check the batteries in the thermostat.
Apr 12, 2011 | Honeywell Programmable Thermostat Heater
I have a 2000 Acura 3.2TL the a/c suddenly stopped
Check your fuses, sounds like the HVAC or AC fuse may be blown.
Apr 27, 2010 | 2000 Acura TL
After a power outage my T8011R display will not come on. Breaker is on and the auto fan works--so there is electricity to the thermostat. Is it fried or is there a reset or fuse that I need to address?
Hi, if the stat is working and running the fan, what has happened is the circuitry is faulty that shows the digital display. Before we are certain this has happened, check to see if the stat has batteries in it. Pull the front cover off and check. If it does, replace them and see if the display returns. If it does great! If not its the circuitry in the stat and will need to be replaced. Keep me posted.
Shastalaker7
Jan 17, 2010 | Honeywell Electronic Programmable...
Thermostat not turning on furnace.
Hi, You need to go to the furnace to see if you have lost the 24 volt supply, the transformer. If you have a circuit board, see if it has a 3 to 5 amp fuse plugged into it that is blown. This will kill power to stat causing nothing to work. Let me no what you find and we can go from there.
Shastalaker7
Dec 29, 2009 | Heating & Cooling
Honeywell T8011r does not have anything on display - does not appear circuit breaker is thrown - could it be wire disconnected at the plate or is there a fuse inside the unit?
Check to see if you have power at the furnace. You thermostat is powered by 24vac coming from the furnace. You should have power on the "R" terminal.
Oct 05, 2009 | Honeywell Electronic Programmable...
My radio/clock digital LD display light is not working
mine blew when i first got my car and its not the fuses its the radio no fix unless you spend big bucks
Jul 09, 2009 | 1999 Pontiac Bonneville
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
My sharp copier AR-5320 just stopped copying and displaying a H
check main power supply socket and plug for blown out fuse,if it doesnt work open the cover on the left hand side to access the power supply board check the fuses if blown replace with the same rating.
Nov 27, 2008 | Sharp AR-5320 Black and White Copier
Honeywell T8011R
Check for either an in-line fuse in the heating unit or a fuse on the control board also in the heating unit.
Nov 06, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
830 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
