Question about Dell Computers & Internet
My dell 2005fpw flashing screen
My dell 2005fpw pcd shows the splash screen then gets all fuzzy then starts to flash on and off,then the screen goes off and the 2 and power button flash and the screen with flash briefly.is this a power supply problem ?
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
Posted on Jun 09, 2010
  • 732 Answers
Creedvr1, It could be a smps/ccfl inverter supply problem. At least that's the first place I would look into if something "strange" was happening to my ccfl back-lit lcd mnitor. If you don't know how the new style curlie-Q energy efficient, CFL light bulbs operate and the technology of "electronic ballast" circuits, then you should do some basic web research here at fixya and youtube to try and understand your monitor's "black screen" symptom. The very first thing to do is prove that your PC works perfectly with a "known-good" monitor. Whenever you need help with a device such as this 2005fpw, you should always state the "date of manufacture" which should be on the rear cover of monitor. If your unit is over 4-5 years old, you may need to have it refurbished with new CCFL lamps and a new inverter ballast circuit installed. It's that or just go and buy a new 20" unit. Good luck on your quest. 12fixlouie
Posted on Jun 08, 2010
Dell 2005fpw flash problem
Often this is a capacitor problem, there have been many problems with them as of late. http://www.badcaps.net/forum post here and they will be able to help you out.
Jun 12, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell monitor 2005FPW keeps on flashing
I was having the same problem.
I solved it by replacing the two 47µF capacitors on the power supply/inverter board.
I actually removed all the capacitors (around 13) and all checked out fine except for the two 47µF.
I forgot to take pictures or even write down the capacitor label on the board.
They are located close to the logic board connector
Feb 05, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Toshiba laptop when desktop is loading screen flashes and starts over again every 10 seconds
If this happens consistently, there is probably a Blue Screen occurring that is too fast for your eye to see.
Immediately after the Toshiba splash goes away, start pressing F8 until the startup options menu shows. Choose Disable automatic restart on system failure. This should allow you to see the error. then re-post with all details including the error code numbers. Then you can get help for the underlying problem.
Dec 30, 2008 | Computers & Internet
CDRom is not present in Vista 32 - Shows driver not working...
Check "Computer" or My Computer and see if the drive is there. If not, reboot the system and go to the System Setup page (hit F2 on the Dell splash screen). Check if the CDROM drive is present under Drive Configuration. If not, reseat the CDROM drive. Remove it from the computer and just put it back in. If you think this is a software issue, backup all your files to a USB flash drive and do an image restore. Hit F8 several times continuously when you see the Dell Splash Screen then select Repair Your Computer. Login on the System Recovery Page. Choose Dell Factory Image Restore. This will bring your computer back to where it started.
Please rate this if this helps.
Dec 18, 2008 | Dell Inspiron 1521 Notebook
Dell screen
Hi...there,
It's open from the front bezel of the screen. But if you are still under warranty...send it back to Dell for repaired... Happy Holidays!
Dec 05, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Flashing on and off
I would suggest trying another monitor to rule out your PC or monitor card. I would also check the video settings on the PC. Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue. In other words, an internal issue that probably needs component-level troubleshooting.
Jan 08, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Screen resolution
1680 x 1050 at 60 Hz is the ooptimal resolution and the only one that will not be fuzzy.
http://support.dell.com/support/edocs/monitors/2005FPW/En/about.htm#Specifioications
press command - shift - a to bring up the Applications folder. Then open System Preferences. Click on Displays, from there you should be able to adjust the resolution
Oct 10, 2006 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Computers & Internet Logo
377 people viewed this question
Alun Cox
