Question about Carrier 36KCARMS Air Conditioner
Wall unit will not blow hard at high speed
I have a Carrier Model 40BNE018-036. It blows cold air but does not blow real hard like it did when it was new. When I first turn it on it blows hard for a few seconds than drops to a lighter air flow. Any ideas what may be wrong?
  • 146 Answers
Try to clean your filters and adjust your setting on the remote
Posted on Jun 07, 2010
Carrier model fa4anf036 blows cold air periodically and doesn't keep the house warm. Eventually starts blowing warm air then cold again
this model number you gave is for an electric furnace , most often its found in mobile homes , if its undersized for the load of the home a larger unit is needed , if I look at this one right here , it says this one will provide 3.6 tons of heat this size will only heat a small area (about 15x25x7 feet ) and wall insulation will help increase this too , also the wall thermostat will " cycle" the heater on an off due to demand , if its placed in a drafty spot then that will affect proformance as well
Jan 15, 2016 | Carrier Heating & Cooling
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
A/c works heating blows cold air
Is this an electric unit? I guess it is. It appears tha the heating elements are not activating. Check to see if the contactor pulled in on a call for cooling>
Oct 20, 2009 | Carrier YC273D Air Conditioner Window/Wall
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
A/C blows weak/low volume of air through vents
I f it is fan that has more then one speed if you run it all the time,it may
not be on high sample : low fan speed runs all the time
med fan speed for heat
high fan speed is usually for air conditioning so if everything is good then it maybe the relay.
May 02, 2009 | Carrier Heating & Cooling
Fan louder than normal
Sounds like whoever did the txv, changed the fan speed. Yes, the fan speed is adjustable. Some HVAC units can have up to 4 speeds on the motor. Low, Med Low, Med Hi, and Hi. this is so the same unit can be used for several different cooling coils and tonage. The faster the speed in the cooling mode, the less cool the air will be.
Sep 29, 2017 | Carrier 38CKC036 Air Conditioner
Carrier 36KCARMS Air Conditioner Logo
133 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
