Question about Canon ZR90 Mini DV Digital Camcorder
When I connect Canon ZR930 on my VIZIO TV, it playbacks on the TV in black and white. Playback on the camera LCD is normal and in color.
  • 128 Answers
SOURCE: Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Posted on Feb 16, 2006
nfandres
  • 168 Answers
SOURCE: black and white playback on television screne
Select the correct color system in your tv. probably the system which was selected in your tv did not match that of your video cam. good luck!
Posted on Feb 15, 2007
  • 37 Answers
SOURCE: Playback STD Locked Playback is Restricted message
the tape most likely has the lock switched on, it's secured so no one can even view it, why it happend, beats me, look at the bottom of the tape, if it has the lock switch, and is pushed up to "lock" push it back down, if  that doesn't work than I'm not sure, sorry.
hope this helped- snowsurfer58
Posted on Nov 06, 2008
SOURCE: My Canon XH A1 will not turn on to record
Check your little lock and standby lever at the back of your hand strap, its likely positioned between standby and lock.
Posted on Dec 20, 2008
welcomejee
  • 10594 Answers
SOURCE: image distorted in both modes canon zr85 camcorder
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced to back in business.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Good luck.
Posted on Dec 25, 2008
Canon 40D playback on viewfinder flashes all white to black. On a wedding gown it is horrible on playback to review.
You're seeing blown-out highlights. These are the portions of the image that have been overexposed so much that all details have been lost and gone pure white. Usually this is a bad thing, and the camera is warning you of it. The proper fix is to reduce the exposure to bring back some of the details. If you simply want the camera to stop the flashing, see page 117 of this manual.
Feb 02, 2013 | Canon EOS 40D Digital Camera
NOT GETTING COLOUR FROM CCTV DVR TO TV BLACK WHITE
Missing information alert. What is meant by "to TV black and white"? Are you saying you can't get playback on a black and white (and therefore old, analog) TV set? What connection set up are you using between recorder and the playback TV? At first glance it would appear you might need a digital to analog converter to process the DVR output prior to feeding it as a SD (standard definition) signal into your TV set for mmonitoring. thanks for clarifiying your question, including a description of your setup.
Dec 23, 2012 | Home Security
No images but records sound
To start ensure that you removed the cover from the lens.
Also remove battery and put it back in place to reset the camcorder.
If you get only sound on playback, connect the camera to a computer or TV, or play the tape on a different camera. If you get picture in there, then the camcorder is recording, but the video playback does not work because of a faulty LCD display.
If when you play back the movie on a different camera, or using the compute you still get no picture then the camcorder is faulty.
Faults that can cause black screen can be:
Lens problem. Faulty CCD sensor. Faulty controller board.
All this faults are not easy to diagnose and fix, if there is a fault , then it is better to take the camera to a repair shop.
Jun 17, 2009 | Quasar VM-L153 VHS-C Camcorder
Recorded image has horizontal lines/brown coloring
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
For the downloading issue, please see:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Apr 12, 2009 | Canon PowerShot A85 Digital Camera
DVR playback in color on TV 2 playback in black and white on TV 1
This is a receiver issue and will need to be replaced as the internal hardrive has an issue that cannot be resolved onsite by a technician. Thanks for using Fix Ya.
Feb 10, 2009 | DISH Network DVR-625 DTV Receiver /...
Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
May 23, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
Black and white playback on television screne
Feb 15, 2007 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Canon ZR90 Mini DV Digital Camcorder Logo
143 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
