Question about Logitech Inc Cordless Desktop LX 300 (DH967427) Keyboard
I just switched over to using a logitech lx 300 wireless desktop, the issue is now when i'm in 3ds max (2010) the middle mouse CLICK (scroll works fine) doesn't seem to respond. (middle mouse button + Alt is to arc rotate perspective camera, and is kind of important)
  • 13433 Answers
SOURCE: scroll wheel not responding. It may be dirty how do I clean or fix it?
Hey,
Check that scroll lock is off
also try reinstalling the logitech software incase some setting is wrong, or you could go over all your settings in the logitech program to see what could be causing it.
Heres the 3200 laser software http://www.logitech.com/index.cfm/433/140&cl=us,en
Let me know how it goes.
Thanks,
Ekse
Posted on Sep 11, 2008
  • 1602 Answers
SOURCE: MX610-wheel not scrolling upward well/erratic.
GO TO CONTROL PANEL AND OPEN THE MOUSE SECTION, VISTA HAS A DOUBLE CLICK SPEED, AND MAYBE TRYING A DIFFERENT TYPE OF POINTER, NOT A SOLID POINTER BUT CROSSHAIRS,POINTER OPTIONS, WHEEL, MOVE THE WHEELS TO 100 VERICAL AND HORIZONTAL. GO TO HARDWARE, AND TO PROPERTIES AND CHECK FOR UPDATED DRIVERS.
EVERY IMPORTANT
SEE IF YOU ARE NOT HAVING ANY INTERMITTING GLITCH WITH IRQ AND DMA CONFLICKS WITH THE SOFTWARE OR HARDWARE IN THE SYSTEM.
GO INTO PROBLEM AND REPORTS
AND OR
SYNC IF IT IS CONSIDERD A PLUG AND PLAY DEVICE.
MAKE SURE THE FIREWALL OR ANY OTHER ANTI VIRUS PROGRAM IS NOT INTERFERING WITH THE MOUSE APPLICATIONS AND OPERATIONS.
THE 3D PROBLEM MAYBE IN THE SETTING OF THE 3D IN THE DRIVERS OF THE OPERATION OF THE VIDEO CARD DRIVERS
HOW TO GET THERE:
OPEN PERSONALIZATION FOLDER IN THE CONTROL PANEL
GO TO DISPLAY SETTINGS OPEN FOLDER
OPEN ADVANCE SETTINGS, INSIDE HERE YOU WILL FIND THE FOLLOWING FOLDERS:
ADAPTER,
MONITOR,
TROUBLESHOOTING,
COLOR MANAGEMENT,
CATALST [TM] CONTROL CENTER, OPEN IT,
OPEN CATALYST CONTROL CENTER AGAIN,
INSIDE HERE YOU FIND THE FOLLOWING SUBJECTS:
INFORMATION ON SFTWARE & HRDWARE
DISPLAY MANAGER
DISPLAY OPTIONS
MONITOR PROPERTIES
3D SETTINGS (OPEN THIS 1 FOR 3D OPTIONS)
COLOR
AVIVO VIDEO
POWERPLAY
HOTKEY OPTIONS
PROFILES
PERFERANCES
VIEWS
HELP ONLINE
AND A DEFAULT BUTTON IF YOU HAVE PROBLEMS SETTING THE SYSTEM TO ORIGNAL SETTINGS IF YOU CANNOT REMEMBER WHAT YOU DID.
RODGANDYSR567
Posted on Mar 05, 2009
  • 12 Answers
SOURCE: Logitech MX 600 mouse - left side not clicking
uninstall the drives,try to download and install the xp driver depending on 32bit or 64bit OS you have, shut down the system, take out the usb mini reciever,start the system when OS comes up insert the mini USB, press the red button on it and then press the red under the mouse, do the same for the keyboard, now try it,solved? no? open the mouse clean it with rubber alcohol around the buttons and try soved ? no ?then there might be a problem with IE of OS, install a fresh copy of windows, try again, soved? no, its a problem with the mouse hardware, try getting a new mouse, c ya!
Posted on Feb 18, 2010
  • 111 Answers
SOURCE: I have a logitech cordless mouse and keyboard.
You can try to update the drivers and double check the batteries.
I hope this was helpful! :)
Posted on Apr 19, 2010
jim4984
  • 797 Answers
SOURCE: My Logitech mouse's scroll wont
This all depends on the operating system. If it is Windows, go to Control Panel, Mice and Keyboards and check that the mouse type is 3 button with scroll wheel
Posted on May 06, 2011
Clicking issues on logitech wireless mouse
  • 1 Use the mouse on the same side of the computer where the Logitech USB transmitter is attached so there is a clear signal between the transmitter and the mouse.
  • 2 Check the USB transmitter that comes with the Logitech mouse to be sure it is correctly plugged into the computer. The red LED should be illuminated on the transmitter if it is connected properly. If not, the signal cannot reach the wireless mouse.
  • 3 Turn the mouse upside down to check the on/off switch. Be sure it is switched on.
  • 4 Check the battery compartment by sliding the top housing off the mouse to confirm the rechargeable batteries are installed correctly.
  • 5 Charge the batteries if the mouse LED does not illuminate. The charger cord plugs into the front end of the mouse and the other end connects to a free USB port on the computer.
  • 6 Clean the desk surface or other flat area if the mouse is not tracking. The problem could be dirt or grease interfering with the tracking ability of the device.
  • 7 Open the Logitech software called SetPoint, which manages the mouse, to troubleshoot button functions. Open the program by double-clicking SetPoint from the list of software on the computer, then click "Mouse Settings." Click the "My Mouse" tab and check (or uncheck) all the task boxes that are desired for operating different mouse functions, then click "Apply" and "OK."
  • Mar 17, 2012 | Logitech Cordless Mouse
    My mouse works fine but not the mouse wheel. It won't scroll up and down but when you click the mouse wheel it works fine.I've tried everything, from mouse wheel programs and everything. I change...
    Hi, I believe you have to clean your mouse. that's no joke. You have to unscrew it and and clean out al the parts with a toothbrush and tooth-pic.. If that does'nt work. replace mouse with optic mouse.
    Good luck.
    Jun 10, 2011 | Logitech "Black" LX 300 Cordless Desktop...
    I just bought this mouse, and I'm a gamer. The scroll wheel works great, but for some games and programs, it doesn't respond. Things like Firefox and a few games accept the scroll input, but things like...
    Wireless mice are a pain.. the batteries are always going dead, the signal dies, etc. For a game,, unless you have a really nice (expensive) gamer's mouse, you would do better with a wired one. It could be cheap mouse, and the USB transmitter isn't working that great, or it could be the mouse. If it's not a standard mouse it should have it's own drivers It will probably "plug and play" but all the features may not work. Run the install CD. If you run the install CD, and it has fresh batteries, and still doens't work, take back and get your money back.
    Jun 12, 2010 | Dynex Wireless Optical Mouse
    LX 300 Keyboard and Mouse: mouse works but keyboard doesn't...
    You can hit Window+U at the Welcome Screen, this will turn on the on-screen keyboard. Reinstalling the drivers should fix the problem
    Also to enter save mode, when the system powers up hold down F8 Key. Use your arrow keys to move to "Safe Mode" and press Enter key.
    Please post your feedback.
    May 18, 2010 | Logitech LX 300 Keyboard/Mouse
    Scroll wheel not working
    pls clean your scroll button..
    Aug 19, 2009 | Logitech LX 700 9674180101
    Mouse not working correctly
    Your batteries could be getting low or your reciever could be too far away.
    Jun 01, 2009 | Logitech Wireless Access Duo Optical...
    REASSEMBLING MOUSE
    If you can't get them back together, it's time to buy a new mouse. And don't open it again. There are no user-serviceable parts inside.
    Jan 21, 2009 | Logitech "Black" LX 300 Cordless Desktop...
    Trying to bind my MX400 Mouse's forward and backward buttons inside of games. I've been using the Setpoint tool, tried binding them to keys on the keyboard with no success.
    Try setting the buttons to "generic" in SetPoint and then assign fuctions via the game options.
    From Logitech Knowledge Base:
    The information in this article applies to the following products:
    All Logitech Mice
    Logitech SetPoint
    Cause:
    Most games that support a mouse will give you options to program or assign specific functions to various buttons on the mouse. These games normally look for generic mouse buttons when attempting to bind the mouse buttons to a game function. If the button is set to another function in SetPoint (such as Universal Scroll, Back, Forward, etc), the game may not see the mouse button as available to bind. This mainly affects buttons 3, 4, and 5.
    Solution:
    To resolve this issue, set the button you wish to program to a generic value in SetPoint. The following values should be used if you are having problems binding buttons in games.
    Mouse Button 3 (The Middle Button/Scroll Wheel):
    In SetPoint, assign this button as Middle Button or Generic Button.
    Note for MX Revolution users: You must disable Logitech Smart Shift Technology or the Middle Button option will not be available in SetPoint.
    Mouse Buttons 4 and 5 (Normally the thumb buttons):
    In SetPoint, assign the thumb button(s) as Generic Button. Note that these buttons will still work in most browsers for forward and back. It is not necessary to assign these buttons to Forward and Back in SetPoint for this functionality.
    May 15, 2008 | Computers & Internet
    Logitech Inc Cordless Desktop LX 300 (DH967427) Keyboard Logo
    35 people viewed this question
    Top Logitech Computers & Internet Experts
    micky dee
    Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
