Question about Hampton Bay 24002 Ceiling Fan
I have three house wires supplied- white, red, and
I am replacing a ceiling fan. I have three house wires supplied- white, red, and black. On my Hampton Bay instructions, it states to connect the fan blue and black wires to the house supplied black wire and then the white to the white and then neutral to a neutral, but the only other wire is a red wire. However, the fan did not work at all. Any suggestions?
  • 736 Answers
Make sure power is off before working on the fan wiring ..(trip circuit breaker)
here is what the house wires are
1. black is hot (power) all the time .. its normally connected to the black wire of the fans speed control switch .. that is normally operated by a pull chain ..
2. red is the same power as black except it comes from a wall switch .. this would be connected to the blue wire in the fan (that goes to its light) .. that will allow you to turn the light on an off from the wall switch ..
3. white is neutral .. it connects to both white wires inside the fan .. one goes to the fan the other goes to the light. .. if there is more than one light bulb then there will be more white wires .. hook them all together and to the white house wiring ..
4 then there is safety ground .. usually green or bare copper ... that is connnected to either a green wire inside the fan or bolted to the metal of the fan (often a green bolt is provided) .. the green wire is not required for the fan to run but is required as a safety to make sure no one gets shocked on the fans metal parts ..
after you wire the fan ..then turn on the wall switch .. if the light doesnt light then pull its pull chain until it does .. you can then tie up or remove that chain to prevent anyone from changing that position since you can now control the light from the wall switch you dont need that chain anymore .. the fan should come on slow med and high then off .. each time you pull its chain ..
Posted on Jun 07, 2010
CONNECTING WIRES FROM CEILING TO WIRES IN CEILING
Don't know that fan because it's a low-end store brand, But, if it has no remote;
White to white
black to black
blue to red ( usually)
If no red wire in ceiling then put black & blue to black house wire.
Sep 06, 2013 | Hampton Bay 24002 Ceiling Fan
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
No wiring diagram with fan ( hampton bay three speed fan with light)
white to white, black to black, blue to red, & green to ground.
If you don't have a second hot house wire(red), then put black & blue from fan to house black.
Nov 29, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
Hello, I have to install a Hunter universal remote receiver, Model 27185 toa Hampton Bay ceiling fan w. light, Model 468-282 today. The receiver has 5 wires, red to light, black to fan, a live black to...
Red from receiver to blue light feed. Black from receiver to black feed to fan. White common from receiver to ground.(bare copper)
Black from receiver (hot) live in, to black from household wiring switch. Common in from receiver to neutral (white ) from house (switch.)
Sep 26, 2010 | Hunter Ceiling Fan Remote Receiver...
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
I bought a Hampton Bay ceiling fan and I have
Hi ,, the usual wiring for the fan / light is that in the ceiling the white wires connect together , the black house wire connects to the black fan wire, the red house wire connects to the other fan wire, usually blue or black with a blue stripe. If this does not resolve the issue, then check the wall switches and see that there is a power wire to each switch and that there is a red wire from the fan on one switch and the black wire from the fan on the other switch ..
Apr 07, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
592 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
