Question about Health & Beauty
I have a Vibrosaun 2000 and it will not start. I am located in Minnesota and I would assume that I need to get a step up voltage transformer to convert european voltage to USA. Is not all 220v the same if I was to hook up to USA 220? I understand that USA is 60hz and Australian is 50hz but wouldn't that just make the fans run faster?
Benimur
  • 6966 Answers
SOURCE: 50Hz to 60Hz conversion
Hi, Your idea is basically sound and should work as long as the UPS originally is designed to produce 240V 60Hz and has its own built in timebase. The reason is that the input as long as the voltage matches makes no difference (50 or 60 Hz). By design, the UPS converts the input voltage to DC to charge the internal battery. The battery then powers an electronic circuitry that produces the 240V 60Hz. The input is then isolated from the output in terms of frequency. This is a common design, however, there are some (not many) that uses for its local oscillation sampling from the source and therefore will replicate the input frequency to its output, but very rare; it's better that you know they exist. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards. P.S. The only problem with 50 and 60 Hz is heat buildup which is tolerable and still within safe parameters. The only time the 50/60 HZ makes a big difference is when motors are used, timers such as in the early designs of microwave ovens, washing machines, etc., pumps and other highly inductive consumers. Most electronic devices converts the AC input to DC and therefore the frequency has negligible effect. Of course others may see it differently.
Posted on Sep 16, 2007
Benimur
  • 6966 Answers
SOURCE: Different HZs problem (from 60Hz to 50Hz)
Yes there are frequency converters available but most are relatively over rated (industrial) for your requirement such as MDS Power or VisiComm Industries. What you need is a Low Power Solid State Frequency Converters lower than a
Electrocon Frequency Converters. However, I expect this devices to be rather expensive.
A few other options you may want to consider:
1. Contact the store where you bought if from; swap with an International version (Model SL-1210 Mark II; same price as SL-1200 Mark II); dual voltage switchable on rear of unit: 120 volts/60 Hz (U.S.) or 220 volts/50 Hz (Europe). You hopefully just spend for the cost of shipping + a restocking fee;
2. Contact 3rd party Technics TT specialist like TopDJGear, Quality Electronics, Planet DJ or DJHardware
and inquire if they would supply you the part(s) that you need to convert the 1200 to a 1210; or
3. Offer a swap on eBay.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Posted on Nov 13, 2007
  • 6 Answers
SOURCE: plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
scrap the trimmer...
probablly damaged beyond cost of new one
a step down transformer would have been a better choice than a voltage converter ( not trying to be a wise guy here)..
Posted on Mar 09, 2009
  • 9 Answers
SOURCE: i HAVE A 115V USA HAIR CLIPPER.LIVE IN UK, SO
Look on the side of the clipper handle. You ahould see what appears to be a screw. With your clipper plugged in and turned on, turn that screw with a screw driver in either direction, the noise you are talking about should quiet down quite a bit,
Posted on Aug 21, 2009
brector3
  • 1623 Answers
SOURCE: I would like to know
T980 models sold in the US are for use with 120V only. You should be able to read the voltage requirements on the charger. This information should be printed on the transformer.
Posted on Aug 10, 2010
POWER VOLTAGE
No. To work with 220V~240v; the device need a step down transformer to be connected in between line and device. The transformer [voltage converter] should be used, otherwise; the unit will get damaged. The step down transformer adaptors can be bought locally. http://electronicshelponline.blogspot.com/
Oct 30, 2014 | JVC GR-D70EK Mini DV Digital Camcorder
Step up convertor
VT 2300F Step Up Down Transformer with American Grounded Plug 2300 Watts
The wattage rating for the router is just under 2000 watts. You'll want a converter with a wattage rating more than the rating of the router.
VT3000 Step Up Down Voltage Transformer 3000 Watts
I would personally go for the 3000 watt converter.
May 19, 2014 | Skil RAS800 Router Table
I live in China and brought a Keurig back with me from America. I went to plug it in a standard converter. The machine turned on for a few seconds and then shut off. I have tried turning it on again. It...
My guess is that the heater in it draws too much power for a converter. US is 110 volts, is China 220 volts? That is a step up transformer and they are not reliable.
yes 220 volts
voltage in china Google Search
Okay, a Keurig draws 1500 watts of power.
HOW MUCH POWER DOES KEURIG BREWER USE
I wonder if you bought a step DOWN transformer, 220 to 110? That would light up for a second until the heater element kicked in.
Does you look like this
Goldsource STU 2000 Step Up Down Voltage Transformer Converter AC 110 220...
or this
ELC 2000 2000 Watt Voltage Converter Transformer Step Up Down 110V 220V...
The other consideration is that the Chinese are masters of copying, so they must make a Keurig clone.
The downside is that the Chinese make rubbish electronics like your transformer.
Feb 06, 2018 | Keurig Coffee Makers & Espresso Machines
What is the 3300-386 transformers function and how do you trouble it ?
transformers step down the a.c voltage to 24 volts a.c. to control higher voltage relays & contactors
Dec 18, 2013 | Coleman Tyco Transformer 240 24 40va...
How to test for bad transformer
  1. To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
  2. You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
  3. Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
  4. To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
Dec 16, 2011 | Emerson LC320EM8 32 in. LCD TV
I have a LG LRE30453SW Electric Range and the relay pcb keeps going bad. I get an F7 error when starting the oven. The first time I noticed the black line in, from the power terminal, to the relay pcb was...
First, check the 220v line and breakers are properly grounded and that you are getting a constant 220v at the plug. Then you will need to check the transformer on the unit.To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
If all that looks good, then you will need to replace the control board. Here is a link to the parts for your range.
Regards,Richard
Dec 08, 2011 | Ovens
1 phase , 50 Hz, 20 KVA , 2200/220 v , is connected as an auto transformer of step up type . Determine , a. The auto-transformer transformation ratio . b. Auto-transformer primary and secondary currents...
This is NOT a forum for college problem solutions. How would you have a 20 KVA transformer and an Atlas Sound AF140... these are different animals... Autotransformer is a more efficient connection when it is possible... the transformer will step the 220 up to 2200+220 volts ignoring the copper loss voltage. For proper designed transformers the primary and secondary copper losses should be close to equal... but in autotransformer connection the efficiency is improved as the added voltage of the supply going to the high voltage winding power does NOT suffer and add to the current required in the primary of this connection. The purpose of this problem is for you to discover that the efficiency of autoformer connection is higher than of a simple step up connection. Now with this carefully work the problem... The ratio I have all but given you... It is unclear what is considered full load here so I would base it on regular connection at 20 KVA at 2200 volts to calculate what the currents would be primary and secondary.in normal connection... calculate resistance of primary and secondary ASSUMING equal losses primary and secondary. What isn't clear is if the loss figures are for the autoformer connection OR just the specs for normal connection. The power factor kink adds to the misery. Approach this problem by making an equivalent circuit of the transformer showing the primary and secondary resistances... again the question is are the loss figures the specs of the transformer or the actual running values for the system....
Sep 11, 2011 | Atlas Sound AF140 140 Watt Autotransformer
Hello! I have a Malibu transformer for my outdoor lighting. Last night, we had a severe rain storm. During the storm, my outdoor lighting went out. When I went to check the transformer box this...
My malibu transformer has a reset button on the back near the terminal connections. If the transformer is on (time displays on the panel) but the light fixtures are not lit, look for the reset button on the back and depress it.
Oct 07, 2010 | Malibu Hardware & Accessories
I live in New Zealand which has 240 volt supply on the grid. The zantrex 2000 works with an input supply of 120 volts. How can I use it?
Hi, OK, there are two ways to achieve this. One. Using an external STEP DOWN Transformer, 240 V AC, to 120 V AC. The ONLY thing that matters is KVA. As long as the KVA is the same ir will work. This means as long as the Output Voltage and Current are the same, it's irrelevant whats on the Secondary. So if
The second, is to remove the existing transformer, and substitute with an exactly the same Secondary Outputs, BUT with a 240 V AC,. Input winding. Most likely it is a simple step Down transformer anyway, that steps down, whatever the external voltage is, down to say 12 -18 V AC. Therefor ANY suitable 240 V AC transformer with the SAME secondary winding(s) will work, no problems. You can even get some transformers Overwound, for 240 V AC, a very common thing, depending on transformer construction. There are a few transformer manufacturers in the "Yellow Pages" contact one of them and inquire.
As a tip, sometimes the existing transformer has TWO 120 V windings, and sometimes only ONE side is used, for US power, and for 240 V AC, you simply connect the other winding in series, and NOW you have got your 240 V AC to whatever.
Sep 01, 2010 | Inverter Xantrex MS2000 Sine Wave Charger...
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
Mar 08, 2010 | Sony Computers & Internet
Health & Beauty Logo
81 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
