Question about Keurig B60 Coffee Maker
It is not heating the water anymore. it just says not ready, and the lights don't blink when the handle is put down. thanks
Your thermostat is not working
Posted on Jun 06, 2010
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Tip
Flashing or blinking green clean light 7 times?
This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light 7 times.
The failure can be wide ranging here are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:
HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Here is a link for instructions on sump clean out
Poor cleaning or noisy Whirlpool KitchenAid or Kenmore
General Dishwasher washability
White powder hard water calcium residue
on Apr 25, 2010 | Maytag MDB8959AW Builtin Dishwasher
My 1991 mercury capri is over heating and the oil pressure goes from 60 when cold to 30 when warn sometimes even drops lower than that
as long as you oil pressure don't drop below 30 you should be good on an oil pump.. as far as your shifter, the pin or bolt may be getting ready to fall off... don't pull on it anymore until you get it repaired or you may get it stuck in drive and not be able to put it back in park.. that could be tragic.
Apr 22, 2012 | 1991 Mercury Capri
When operating, water leaks from the edge of the filter holder. Could there be leakages within the water pump system enclosed within the housing? Are there any tools suitable to remove the warming plate?...
Hi had the same problem. Probably it is the steam/hot water valve that leaks. I just bypassed it since you can not find it anymore & is from plastick, not reparable at all. Open top cover, see if at the right, where the handle to choose steam is the plastic valve is leaking or if it is covered with white powder (residu of calc of the vapourated water). If so this is the problem. Disconnect at te bottem of the valve the tube coming from the heater. (untighten the screw, pull tube out the hole, it is a sort of press fitting with a rubber ring) . Do the same with the connection on top of the heating blok and fit the first disconnected tube in it. No leak anymore. You can not have heated water or steam anymore. But coffee works again. Best is also to fix the staem handle into the neutral position, or disconnect the wires on the switches an put them permanently in the neutral status. (one switch is closed, the other is open. So nobody can trigger the steam anymore. Will not be ok since tubing is changed. Succes.
Feb 27, 2011 | Bodum GRANOS (3020-16US) Espresso Machine
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
The lights are blinking and I can not turn on the dishwasher.
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
Jun 22, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Euro-pro iron. red light on. green light blinks on but iron will not heat up. lights do not progress through yellow (does not go past green) purchased from walmart with warranty extention on 12/08. ...
When the green light stops blinking and is solid, the iron is ready for use. Touch the handle and begin using. but as you mentioned that green light is blinking and the iron is not heating then there is definitely a short in wire some where it has to be checked.most probably its the short in the heating coil wire.but if the heating coil wire is proper and not short then your irons heating coil probally went bad its alot cheaper to just buy a new iron .because heating coil costs near to new iron.but still get confirm if its short in wire. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Apr 18, 2010 | Vacuums
Keurig won't turn on, power light just blinks green
Try picking up the handle where you put the coffee and kinda slam (not too hard) back down. I found that resets the coffeemaker. Also when you make coffee I also noticed that you when the water is hot you have to pick up the handle again and put it back down then the two blue lights start to blink and you decide what size cup you want.
Apr 12, 2010 | Keurig Elite B40 Coffee Maker
Keurig B60 Coffee Maker Logo
297 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
