Question about Ryobi Backpack Blower 25.4cc
My ryobi 25cc leaf blower rarely can make max rpm. runs fine otherwise, just can't get the engine speed it used to have. it is about 4 years old and hasn't seen too much use.
    Problem Solver:
  • 10 Answers
First thing to check is the screen (spark arrestor) on the muffler if it has one. When these get clogged units often will idle fine, but not be able to rev up much or at all.
If the screen is clogged, clean it and reinstall it, should work fine then.
Posted on Jun 09, 2010
My Ryobi leaf blower will not rev up to max rpm I replaced the carb but I have the same issue
Replace the fuel filter in the tank. Fish it out with a hook on a piece of wire. Good luck.
Nov 15, 2015 | Ryobi Garden
Leal blowermodel RY09460 will not run at full speed why?
High side adjustment needs to be turned CW to achieve highest RPM, then back it off 1/8 turn approx..
Jul 22, 2014 | Ryobi Ry09460 4 Cycle Gas Blower
I have a Red Max HBZ2600 Z Power blower that starts runs a few minutes then slowly dies. Fixable?
Install a new spark plug
Clean or replace the air filter
Use only gas that is no more than 2 months old
& add fuel conditioner such as Sta-Bil or B&S,
unless you have to mix fuel for a 2 cycle motor
Once running & fully warm,adjust carb screws for
fuel mix at idle & fast rpm, then set the idle
Check for spark with a small engine tool avail for that
It looks like a spark plug with a clip on it & avail many places
May have to remove the carb,clean it & install a new kit,if
you still have problems
Jun 09, 2014 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Poulan pro blower will not build up blower speed
start it up and at full throttle adjust the hi speed carb jet to get max speed.
Oct 30, 2013 | Poulan Pro 25cc 2-Cycle Gas Blower...
It will cut out when i give it full trottle,it idles just fine .its a ryobi 31cc 17 in
You can adjust the 'H' - high speed needle by removing the plastic carburetor cover by removing the 4 torx screws. On the carburetor, there may be a 'L' and 'H' needle. (Ryobi used two different carburetors on this model and one may not have a 'L' and one may not be adjustable with common tools). If the 'H' needle is adjustable, start the machine, warm it up and go to WOT (wide open throttle). At WOT, turn the screw about 1/4 turn out or in and see if the engine speeds up. If it does, fine the point in which the machine gets the highest RPM's and then back it off about 1/8 turn.
Note: This is a sign of a carburetor that needs to be cleaned and rebuilt with a new fuel metering diaphragms which would be common if the machine is > 4 years old and you did not completely run the machine dry of fuel in the fall. Rebuild kits available for about $15 through local sources or $10 through ebay.
Sep 16, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Ryobi Garden
25cc poulan leaf blower runs but will not rev . it has to build up to a higher but no balls rpm
It may be old gas not allowing it to rev up. or the carburetor diaphragm may need replacing. I would say at 25cc engine is not going to sound or rev up like a more expensive blower.
Sep 30, 2009 | Poulan Garden
Low RPM's Ryobi 25.4 cc backpack blower
Remove the muffler and you should find that it will run at full speed. The muffler is clogged with carbon. You will have to replace the muffler since it is sealed. If you want the muffler cleaned you can contact southern supply company at 205-833-2525 or email them at
southern.supply@mindspring.com and I feel sure Jason or
someone there can help you.
Sep 03, 2009 | Ryobi Backpack Blower 25.4cc
Leaf blower will not achieve full RPM's
try removing the muffler and scraping out any carbon build up in the exhaust mouth of the block. if that doesnt help you will probably need to replace the carb.
Nov 15, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Ryobi Backpack Blower 25.4cc Logo
698 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
