Question about LG GH22NP20 22x Internal DVDRW Retail Kit DVD±RW Dual Layer Burner
I've got a new LG IDE DVD-RW that won't accept self boot. I tested the new LG IDE DVD-RW on another PC (not Intel Motherboard) found accept self boot. I used another ASUS IDE DVD-RW on my computer it is working satisfactory. I checked jumper position 3 options on LG IDE DVD without getting a positive result. I took the LG IDE DVD-RW to the LG service center in CAIRO, they told me after testing nothing wrong and they told me check your pc (Intel Mother Board).
  • 26 Answers
IT must be incompatible , check your BIOS settings to see if it is detected in the bios
Posted on Jun 08, 2010
I just installed a BLKD915GVWBL LGA 775 Intel 915GV Intel motherboard in a new computer i'm building. everything powers up but no video. i have tried 3 different moniters. what's the problem?
You need to perform a quick check of the following steps for us to understand the exact status of your SMPS(power supply) and Motherboard
1) Open the CPU and check whether the green light is glowing on the motherboard when power is given to SMPS.
2) Please make sure that the HDD IDE/SATA and power cables are plugged in properly on both ends.Use common sense to check, do not press very hard as the slots are sensitive.
3) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
4) Make sure that the Jumper setting on the back of the HDD is set to MASTER. NA for SATA.
5) Remove any VGA/Graphics card that you have installed. Also remove any PCI cards that you have installed.
6)Connect the monitors VGS cable to the Blue 15 pin female VGA out port of the motherboard.
7) If possible login to bios and make see if you can find the HDD from the drives menu. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Note: Please click on ' Accept' to accept my answer because it is your Acceptance, which gives us motivation to assist you with more efficiency.
Mar 11, 2012 | Intel D915GVWBL Motherboard
Acer 5102 with xp, It wont boot from cd.
Make the DVD your 1st option for booting. It's also your CD drive but is identified as the DVD RW. Once this is made your default (make sure you accept and save the change before exiting) with your installation disk in the drive, boot up and it will read off the disk and prepare your system for install. If your disk is bootable, this will work.
Dec 19, 2009 | Computers & Internet
USB driver 2
Can you be more precise? You don't need USB driver for this PC...
Jun 25, 2009 | Gigabyte Computers & Internet
Motherboard driver
here all the utility to your motherboard, download in this site: http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2669
Jun 17, 2009 | Computers & Internet
DVD Drives not working
maybe a bios update and latest motherboard / chipset drivers ?
Also ensure that the sata and ide cable are seated firmly at both ends
what make is the motherboard ie asus etc ?
Apr 17, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
No sata l type on my motherboard
the only way i know is to buy a convertor like the 1 from the link
http://www.cooldrives.com/serial-ata---ata-atapi-ide-interface-adapter.html
might be easier to just swap the drive you have if youve just bought it or buy a new ide drive
Mar 13, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
PC shuts down on Asus P5sd2-vm with LG DVD Rw (GH22NS30)
If you are sure that it works with other DVD drives, then I cannot help.
But if a system shuts down suddenly, the first thing I would check would be the CPU temp. At around 97 degrees, Intel processors shutdown to protect from excessive heat. Go into the setup (some call it BIOS) and check cpu temp.
If that's not the problem, then you should consider things like drivers problems, virus infection, broken hardware, compatibility issues. Try to search technet site at microsoft for a similar problem.
Good Luck!
Tareef Attar, MCSE, CISSP, CISA
Dec 19, 2008 | Computers & Internet
Re: lg tower xp install
the boot device setup in the bios, if you set atapi-cd rom as first boot device. then hdd second. and fdd last.
it appears that you have a faulty connection from the IDE ( 40-80 wire cable ) that runs from the motherboard Primary/secondary slot. check the cable goes from motherboard to hard-drive and is connected firmly, also check the jumper blocks ( small white plastic block ) is set to master or slave on both devices ( cd-hard-drive ) if both on same cable set hard-drive to slave and CD rom to master. if they are both set as master or slave, they will conflict with each other.
if you need further help, please mail back.
mike @ compurepair.
Mar 29, 2008 | Computers & Internet
LG GH22NP20 22x Internal DVDRW Retail Kit DVD±RW Dual Layer Burner Logo
171 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
