Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Run out of diesel gas. Filled it up and now it won't fire. only turns over. Is there something we should do when we run it down to empty?
  • 59 Answers
You need to bleed the fuel right through to the injector pump. If there is no valve for the purpose you will have to loosen the pipe unions progressively towards the pump until fuel flows at all points one after the other. Many modern diesel engines have a valve and auxiliary hand pump to do the job .
Posted on Jun 06, 2010
Simply spray a little starter fluid in the air intake. Don't spray alot cause the engine will knock when it is trying to start.
Adios.
Posted on Jan 30, 2011
Wont run and emits white smoke
Hi Jeremy:
Sounds like there is still diesel in the fuel system.
There will be a plug on the bottom of the carb.
If you unscrew it and allow it to drain, it will flush the carb.
I'd suggest changing the fuel in the tank again.
You may also need to change the spark plug.
You won't have damaged the engine.
Cheers.
Jun 27, 2016 | John Deere Riding Lawn Mower. EZtrak Z425...
Starting problems
Hello David,
It sounds like by reading the second sentence that your problem began when you filled it up. Are you sure 100% that you put gas in your car and not diesel by accident? That would most certainly cause all your issues. Get a sample of the fuel from the carburetor or fuel line leading to it and verify that it is indeed gas. If it is diesel then you've got to purge /empty it all from the tank to the carb of the diesel fuel! This can be a very messy and possibly dangerous job especially while dealing with gas. Make sure you have lots of ventilation when doing this fuel swap if it applies. Good Luck!
Rich Lilja
Apr 03, 2014 | Saab 900 Cars & Trucks
Gas tank ditech
If you have put diesel in, disconnect supply pipe to injector and allow to drain, flush through with fresh petrol. Reconnect pipe and crank engine over, will take some time but should start, if it doesn't you may have to replace the spark plug, as the diesel will have gummed it up. Will smoke a bit when it starts but will clear. If you have just filled up with the wrong grade of petrol, just fill up with correct grade and run it through, shouldn't be a problem
Oct 28, 2013 | 2011 Aprilia SR 50 R Factory
My 1994 Jeep Grand Cherokee won't start. It turns over but won't ignite or stay running. It was running fine until I filled up with gas and was driving home. I've tried to reset the security system wi
The gas u put I'm the tank was high octain if it was it was making the engine fire to early replace the gas and it should wor properly
Feb 16, 2013 | Cars & Trucks
Someone filled my tank and they put diesel instead of gas 1999 ford taurus what's the cheapest way to fix
this is a nightmare situation as the whole fuel system will have to be drained,all filters changed,and then refilled with the highest octane fuel you can buy(to dilute any diesel left in tank)most main dealers pressurise the tank and then when empty fill with gas and pressurise again when changing filters etc.....if you have a compressor it IS something you can do yourself but will take all afternoon.......(then you have to dispose of the old fuel)
Oct 25, 2010 | Ford Taurus Cars & Trucks
I cant get my 99 dodge diesel started after draining water from fule.
air lock maybe need to bleed it or remove filtre fill will clean diesol and refit and prime it
Feb 18, 2010 | 1999 Dodge Ram 2500 4WD
Car won,t fire up but trying to turn over its as
Lots of reasoons for a no start this answer is as if it was running OK just the other day and was starting OK. The gas tank has gas? Spinning real freely indicates to me that the timing belt broke. The oil cap off the valve cover look in there to see the cam and crank engine you should see it turn. The fuel pump may not be coming on. The fuel filter could be frozen not letting the gas go though. The spark may not be happening as A senser or also a plug wire or other wire off inspection of these things something off can be the only problem
Feb 08, 2010 | 2002 Volkswagen Golf
Put diesel fuel in on accident pumped fuel out from fuel line in front of filter, filled up truck with regular fuel now runs bad and fuel pump is on continuous when running and pump ismaking loud noise
The diesel fuel is not a good lubricant for the pump and plugged the sock inside the tank replace the fuel pump and sock also pull spark plugs and clean I am sure it is running like ******* the diesel coats the plugs so they won't fire without being cleaned. Gas is much thinner than diesel and the gas lubricates the pump once the diesel washed off the bearings in the pump if most likely finished off a pump about to go anyway.17 years is a long time for new pump to last and in 92 they were not putting in the junk they are now in our fuels. If you need more help or want a price on the pump let me know.
Jul 31, 2009 | 1992 Nissan Pickup
97 gtp turns over wont start..fuel pump runs enermidintly
yep i seen it in happen .i was at a gas station a guy drove car to the gas station on empty.he fill his tank up .could not get it to crank .some cars you have to restart fuel pump when run out of gas. like chrysler.you use a scanner. but chervrolet you run low over heat damage the pump.it has to stay submerge gas to keep it cool. check fuel pump pressure.it should be 41 - 47 psi.
May 05, 2009 | 1997 Pontiac Grand Prix
Gas gage constantly says full when it's not!
Unfortunately this is most likely the fuel pump module, which includes the fuel level sensor also. This should be diagnosed more thoroughly with a scanner, a good scanner will be able to check instrument cluster separately to confirm the gage is working right,and check for trouble codes that may not light any warning lamps. Hope this helps. Rate me please.P.S. Dont use that fuel station any more.
Jan 21, 2009 | 2002 Chevrolet Malibu
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
590 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
