Question about Belkin (F5D5231-4) Router
Cant go to setup for my router 192.168.2.1 - Belkin (F5D5231-4) Router
    Guru:
  • 868 Answers
You can't access your router IP address? are there any errors? have you connected your computer to your router using ethernet while accessing the router? cause if try accessing your router wireless it will not work this should be done hard wired using an ethernet cable ^_^ also have you tried resetting the router to default by pressing the pinhole on it press it for 5-10 seconds then let go try accessing the router again ^_^
Posted on Jun 06, 2010
3 Suggested Answers
Tom Marvolo
  • 708 Answers
SOURCE: cant get into the settings of my belkin router http 192 168 2 1
Step 1 : Check the IP Address of the Computer
Step 2 : If it is in the Range of the Router ( 192.168.2.x)
Step 3 : Try typing 192.168.2.1 on the address bar of internet explorer
Step 4 : If not working Hard reset the router by inserting a paper clip into the reset hole on the back of the router
Step 5 : If the IP Address is any public address or 169.254.x.x then also do step 4
Posted on Jan 10, 2010
eastpole
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
Cant open setup page
Connect a Ethernet cable from your PC directly to the router and try to open the page 192.168.1.1 with "admin" as user and password.
Nov 30, 2013 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I have a router i forget everything to it i cant get into it at all cant access the internet or nothing
To access a router on which you forgotten everything, do the following...
1. apply power to the router and connect an ethernet cable from PC to one of the router's LAN ports
2. press the router's reset button (usually located beside its power supply jack) for at least 5 seconds
3. (pressing reset for 5 seconds resets the router to its factory defaults)
4. with factory defaults, you can now use the Setup Wizard on the router's Setup CD-ROM
5. if no Setup CD or to configure advanced settings see router manual about web-based utility
6. open Internet Explorer and enter the router's default IP address (see router manual for address)
7. IE presents a login window for entry of router userid and password (see manual for defaults)
8. once into the router's Basic Setup screen, follow the steps in the router's manual to do the setup.
9. if your ISP requires a registered MAC address, enter it on the clone MAC address screen
10. for better wireless security, change router SSID from its default and enable WEP or WPA
Feb 22, 2011 | Computers & Internet
I cant find my security string
Ok here is your solution.
  1. let me know your Windows operating system
  2. check your Security type setting in your router
  3. channel and SSID sharing
  4. disable Firewall in router
Check your windows firewall and some anti virus who cant also block your signal.Go to setup page Belkin using 192.168.2.1
If you cant open it just reset router,go in the back of your router and locate the reset ping.
if you still cant do it just check your physical connection and go to command prompt using RUN and type CMD after ping router 192.168.2.1 and you will get a four answer and zero lose.
if you still cant do it ask me for a remote setup in your pc .
If you are able to open Belkin setup page using 192.168.2.1
Check all configurations and be sure you can setup it to wep64 bit security mode and your problem will be solved.
Sep 18, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Cant setup or connect to internet through router
Different ISPs require different configurations. If you have a Linksys router, such as the WRT54G, there are 2 ways on how you can configure it, either by running the Setup CD or by doing manual configuration. This particular router has its own web utility and you can access it by typing its IP addres on your web browser, ex. http://192.168.1.1. By default, it doesn’t have any username and its password is admin.
Once you’re inside the setup page, you can configure now the router for DHCP, PPPoE or STATIC IP settings. For DSL customers using a PPPoE account, some modem needs to be configured into BRIDGE MODE first and then the router will be set to PPPoE with the correct username and password (given by ISP). If your a DHCP account, modem doesn’t require any configuration. It will work with its default setting and the router would be set to DHCP. Once done, powercycle your devices to establish internet connection.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
Cant find my ssid or wep for my dsi
i dont remember my stuff to log on my router. i cant find my WEP is there any other way of finding it?
Feb 22, 2010 | Nintendo DSi Blue Console
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Cant connect to the internet
connect the computer to the router and the modem to the router.
you will need to open the setup page of the router to check the settings of the router.
you can setup router without the cd also.
It is very easy.
Click Here for more info
Dec 04, 2009 | NetGear WGT624 Wireless Router
I cant access the router's web-based setup
1. go to start -> run -> type cmd
2. at the prompt type ipconfig /all
3. note down the IP address of your default gateway
4. enter this ip address in internet explorer. eg. http://192.168.1.1
5. enter in your routers default username & password. ( usually admin for the username and admin for the password.)
Mar 17, 2009 | Computers & Internet
Setup cd
You can setup the router even without a CD setup, if you know how to access the router setup page where you can do the configuration that will do the setup, But if you're not familiar with it better contact Linksys tech support so they can walk you through with the process on how to set it up without the CD this is the number 800-3267114.
Hope that helps.............
Aug 25, 2008 | Linksys Wireless-G WRT54G Router
Cant not setup my d-link router 300
connect to the router by cable
http://192.168.0.1
is the routers web address, will open the menu set to set up the router, and allow access to a set of helpscreens to explain setup of the router
Jul 14, 2008 | Computers & Internet
Belkin (F5D5231-4) Router Logo
423 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
