Question about Vizio VU42L 42 in. LCD TV
Visio VU42L-fhdtv10a No audio or Video
Unit made high pitch sound after a/v went away. Unplugged to turn off then turned on with power button and noise went away but still no A/v. Power button won't turn the unit off. Checked 24, 12 & 5vdc on power board all ok. No capacitors seem to be leeking. Led's still operating as glow from screen is good and both the inverter oscillators still humming.
Is it the power board digital cicuits or the control board? I need to buy one or the other and am trying to determine where to best spend my money. Please help!
  • 10,594 Answers
By given symptoms, it seems main board (digital board) is defective.
Because power supply board is giving correct volts on output connectors, no capacitors are leaky, back light inverters are producing back light that means power board is just fine and working properly.
(lcd) controller board has nothing to do with high pitch sound nor it can interfere on-off function of tv that controls by system control chip mounted on main board. LCD Controller Board job is to get video data for scaling and send it to lcd panel inbuilt internal large scaling circuits to control lcd pixels to make an image.
Replace main board to solve your tv problem.
Hope these info will help you.
Thanks.
Posted on Jun 06, 2010
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
How do I test a High Voltage Transformer on my Vizio VU42L-FHDTV10A?
It could be the main board. The main board controls the standby light on the front of the set. Check and verify that your 5vdc standby voltage is working. Next, I would check the "on" or "ps on" input on the power supply board. When you turn the set on (either my side buttons or remote) the main board should send a 3.3vdc signal into the "on" terminal on the power supply. This "on" signal from the main board turns on the other half of the power supply thus turning on your set. If you are not getting this signal from the main board, I would suspect the main board. To test your power supply, you can simply put a jumper from 5vdc to the "on" terminal on the power supply. Your 12vdc, and 24vdc power supplies should then become active.
Oct 31, 2012 | Vizio Televison & Video
Vizio VU412L 42" made a
The pop has been generated by the explosion (literally) of an capacitor from the power board of the tv. When that happened the power source has been shorted and, if you're lucky, it went in protected mode. Fixing that is a relatively simple job - all you need is a soldering iron and a basic experience in using it. Follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
If you're unlucky the entire source has been fried and it will have to be replaced - here's a good one
http://cgi.ebay.com/VIZIO-VU42L-FHDTV10A-POWER-SUPPLY-DPS-283BP-C-REV-S0-F-/370477438027
Mar 06, 2011 | Vizio VU42L 42 in. LCD TV
When I went to turn on my 20 month old 46in LCD LN46A500 it made the loudest high pitch screeching sound that no one would like to hear and the picture was black. The remote buttons and the TV control...
The power supply board have fail badly,all that high pitch screeching sound,it came from those high voltages gaps from those tranformers,that giving ur tv high voltages.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Samsung LN46A500 46 in. TV
3 y/o Visio VU42L with no pix or sound
well,mike seems youve done everything to your TV and nothing happen..Try to reset the system of your TV.On the main board there is a small button just press it to reset your system and see if your TV will work again tnx.
i hope i help you..
please rate my help...
Jun 06, 2010 | Vizio VU42L 42 in. LCD TV
High pitched ear piercing tone when turned on.
sounds like you have a crossed wire somewhere
May 19, 2009 | Car Audio & Video
On off button blinking.
If your set is making a high pitch sound or chirping sound you can get a repair kit from www.TvRepairKits.com.
It will fix the no audio + no video + set makes chirping or high pitch sound.
Dec 27, 2008 | Philips 43PP9202 43" Rear Projection...
VIZIO VU42L FHDTV10A screen goes green sometimes
I need a screen for my vu42l if anyone near Connecticut has one. If not, I have parts from a vu42l.
email mbsimonds AT aol DOT com
Aug 11, 2008 | Televison & Video
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Vizio VU42L 42 in. LCD TV Logo
203 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
