Question about Sharp UX 355L Plain Paper Thermal transfer Fax
How do I reprogram the fax cover sheet? I bought the fax machine from someone and I would like to put my name on the fax cover sheet. I have a sharp ux-355L
While holding down the start and stop button with two fingers,
pull the plug from the wall, wait ten seconds, plug back into wall while still holding the two buttons, after plugged in take fingers off that should reset the fax.
Posted on Nov 07, 2010
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
Bought a Brother 560 Plain Paper fax today at garage sale
Pull the upper part towards you...load in about 30 sheets....push cover back.
Put originals to be faxed in lower section, dial in fax number, press start.
Jun 17, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Sharp UX-A1000 Fax Machine Document Feeding Trouble
Problem is most likely caused by a worn paper pick roller. It would be more expensive to repair this fax than to just replace it.
Nov 28, 2008 | Sharp UX 108 Roll paper Thermal Fax
Add and delete names and numbers from broadcast
How do I change the name and phone # on my fax machine. Sharp UX-510
Nov 25, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
How to save fax numbers
press Function
72
set
1 for ONE TOUCH NUMBERS
set
press 01 on the soft pad
enter fax number with the DIALING NUMBER KEYS
set
enter name with LETTERS on the soft pad
set
continue with 02, 03, 04 etc.
when done press stop.
press Function 67
set
cut out directory sheet on dotted lines and put under the mylar sheet on the soft pad.
press Function 62 set to print out the list of one touch numbers.
Nov 19, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Will not receive Faxes
The first thing you can try is replacing the phone line between the wall and the fax machine.
Sep 15, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Transaction report
if you go here http://www.sharp.ca/manuals/default2.asp you will find the download of the op manual for that Facsimile Machine.
May 27, 2008 | Sharp FO 3150 Plain Paper Laser Fax
Open Questions:
Sharp UX 355L Plain Paper Thermal transfer Fax Logo
116 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
