Question about Garden
My ford 1210 tractor is blowing black smoke. I've
My ford 1210 deisel tractor is blowing black smoke. I've change the fuel and air filters. This did not fix the problem. It also seems to loose horse power after engine temp increases.
  • 36 Answers
Your injectors are set to rich
Posted on Jun 07, 2010
MY 94 rodeo 2.8lt turbo diesel blows lots of smoke when the throttle is down.. When i lift the foot of it stops smoking.. can you help..
if its black smoke and id say it is being a deisel it can be injectors or just simply fuel pump timing. get it to a deisel specialist to check the pump timing and your fuel load under acceleration, only real way to get it sorted.
Jun 28, 2011 | 1994 Isuzu Rodeo
Can my EGR , couse black smoke when i aply the trotle and some times trys to stall outand i get a loud clacking like ny lifters are not getting oil to them , This is on deisel 6.5 turbo.
BLACK SMOKE SIGN YOU NEED TO CHANGE AIR FILTER,BUT CLATTERING NOISE COULD BE THE INJECTION NOZZLES CLOGGED OR DEFECTED. YOU COULD ALSO HAVE BLOCKED FUEL LINE OR CLOGGED FUEL FILTER. FAULTY INJECTIONS NOZZLES HAS TO BE REPLACED CANT TAKE APART CLEAN THEM.
Feb 24, 2011 | GMC Sierra 1500 Cars & Trucks
I have Hyndia Tucson 2006 Deisel. I have a problem in it. This problem is smoke heavily (Black) and there is no intention of any force during press the accelerator.
mean there might be fuel leaking into the engine or the air to deisel ratio is and not atomised correctly. the main causes are normally is the air filter that isnt allowing air into the engine. Fuel filter can also be at fault not allowing enough fuel in or allowing to much in the engine sometimes. This causes the chamber to burn it out. Fuel injector if fualty could allow to much fuel or not enough. My personal suggestion would be to run fuel injector cleaner first, then change the air filter. If that doesn't fix it change the fuel filter. I would go the cheapest route first. Is is prolly something simple
Nov 07, 2010 | 2006 Hyundai Tucson
Tractor won't run
If it is spitting black smoke, it is getting too much fuel. Try taking off bottom of carb assembly to get at the float. Make sure that the float doesn't have a hole in it and that the needle is in place
Sep 12, 2009 | Garden
2005 chevy 6.6L turbo deisel losing power and blowing black smoke
pump may need recalibrating or a kit through it
or you may have a cracked turbo
Jul 20, 2009 | 2001 Chevrolet Silverado 2500HD
Ford f250 diesiel sputters blows black smoke dies
youll think im crazy but change the oil and look for a oil leak, prob around the fuel filter
Jun 14, 2009 | 2004 Ford F250
Ford focus 1.8 turbo deisel 1999.
do not understand you what you mean. assuming your car was ok before you changed f/filter you need to bleed the fuel system of air. esiest to do would be to loosen fuel line at the injectors and have assistant crank the engine while you observe for clear fuel leak without any air bubbles from fuel line.tighten fuel lines and start engine. might have to repeat a few times. good luck.
Jul 03, 2008 | 2000 Ford Focus
Garden Logo
337 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
